BlueSkyNick
... came the cry from the skipper of a boat I was on recently, as I tried to furl a flogging headsail on a 40 footer in a F4/5.
I did as I was told at the time, and eventually got it in by hand over handing on the line, then asked what the issue was.... too much lateral strain on the furling mechanism came the reply.
I explained I was not using or intending to use the winch handle, so with just a couple of turns on the winch and pulling by hand I was simply using it as a method of making it easier to furl, but using the friction on the drum to prevent the sail pulling back. No additional gearing hence no additional tension. Had I put the line in the self tailer and started cranking the handle, it would have been a different issue.
The skipper maintained that the furling line should never go on the winch - much better to bear away to blanket the sail behind the main, to make it easier to furl.
Comments invited.
Comments invited.
