Paul&Ness
HI, Went to the boat today to do some post trip checks and found that the bilges were full of water. Much higher level than the normal amount I see in the bilges! It turned out that the engine bay bilge pump had burnt out... to cut a long story short, I replaced the bilge pump and float switch with an automatic bilge pump. As it sometimes is with boats the bits that you need to replace are the least accessible and trying to squeeze my big a*se in the engine bay was quite a feat.
Having solved one problem I, rather stupidly, decided to check the gearbox oil levels. Levels in both gearboxes were good but the port gearbox oil has signs of water contamination! So I'll be flushing the gearbox out a couple of times tomorrow but will have to replace the oil cooler.
So I have a questions or two... are Gear Oil Coolers reparable and if so can someone point me in the direction of where I can get them repaired.?If I have to replace the gear oil cooler, where can I get a replacement? ASAP Supplies don't have a like for like replacement, I have just checked. SBMarine in the US do have direct replacements but the cost + import duty make them very expensive.
Any suggestions will be gratefully received :encouragement:
