pvb
Are you towing a field full of PV panels behind your boat? A string of dumb barges maybe?
He has plenty of space in the garden for solar panels.
One of these? We've had one for years and it is really useful on a small boat with no oven..
Have you done the maths on how much power an induction hob etc uses. Also read why Elcano flattened it's batteries, even with twin saildrive generators, solar etcI'm talking to the licensed gas fitter tomorrow about doing the plumbing for my lpg stove on the yacht. I planned to toast using the griller
.View attachment 122607
But now I've swung right away from gas and I'm going to see if I can use 240V induction hob, microwave, electric kettle and toaster all powered by solar panels. Maybe I'm expecting a bit much?
I have a 3.5kva suitcase generator as well.Can I have one of your 700W toasters that does 4 slices at a time in a couple of minutes please?
700W on an inverter will equate to at least 70A from a 12v battery, do you know how long it will take your PV panels to put that back in?
but I maintain you can do it in the dry frying pan with a lid on.
That's the one.One of these? We've had one for years and it is really useful on a small boat with no oven..
But it takes a lot longer = more gas.Toast is best done in a dry frying pan. We’ve tried a number of stove top gadgets to make toast, none of which produced decent results. However, a dry frying pan works brilliantly: you just have to get it hot enough. Once it’s hot, it’ll produce toast in a couple of minutes. Never bothered covering it, just don’t use one of the fancy white ceramic coated ones: the toast will leave burnt residue on the coating which just won’t come clean.
No it doesn’t! Using any of the many gadgets takes at least as long to produce unsatisfactory results. Thats why we’ve junked the gadgets and just use the pan.But it takes a lot longer = more gas.
I use one of those in my camper (no gas in boat). Works well enough but too quickly even with gas turned down. I get well done on the outside and"raw" in the middle.Brilliant, cheap, rapid and gas saver.
Highlander Folding Grill Toaster For Gas Stoves Stainless Steel Easy Storage | eBay
Big boat?used to get wonderful toast on an Aga, on the hotplate, put the lid down.
I was sanguine until the atrocity occurred; who thinks spaghetti, hoops or otherwise, are an appropriate breakfast component? This is a breakfast warcrime.I have a Ridge Monkey XL. Does good toast & i can do all sorts of meals in it , including a full english breakfast
I also have a smaller Ridge Monkey for toasted sandwiches & the odd single burger, sausages, or a bacon sarnie in the morning
Great pieces of kit. Can also make things like corned beef hash & make a meat pie. Does good steaks as well
Ridge Monkey Breakfast
Review
Ok hears my “possibility” Controversial idea , get a 240v “alternator style” Generator that bolts to the engine , then buy a cheap 240v toaster from Argos and just Start the engine for 2 minutes when you want to do the toast, job done ??, ok some will say starting the engine and running it for 2 mins will ruin it , and the cost of the parts etc and not to mention that Greta thunberg wouldn’t like the carbon
Emissions much just to make some toast ?????? but you would get some nice toast on board
