Steve Clayton
I met a friend in the gas/plumbing business last night. He had the March 2004 issue of the magazine “Gas Installer”. Two articles therein with regard to Gas on Boats.
One was “Room-sealed gas appliances used in boats” which looks at gas warm air heaters and hot water heaters used in the marine environment and the second was with respect to gas detectors in non-domestic and LPG installations.
Tells you what BS references apply to boats under 24 metres- these are BS EN ISO 10239:2000 and a “National Annex” and BS 5482-3:1999. The general consensus (quote) is that 10239 is used for new installations and 5482 is used for maintenance and installations that were installed in 1999 and prior (ie pre 10239 coming into force)
Gives information on what to do if an alarm sounds and if you’re in the Isle of Man, Guernsey or Jersey the contact numbers in the event of a serious incident.
Incidentally and I’ll quote:
“Not all work carried out on boats falls under the scope of the Gas Safety (Installation and Use) Regulations (GSIUR); eg boats privately owned, boats NOT hired out to members of the public as a course of business and boats which are NOT used primarily for residential purposes. However, any person undertaking work on a boat should be competent. The waterways authorities recommend the use of CORGI registered installers”.
A future article for P.B.O. possibly??
