Garmin chart plotter and AIS
jimi
19 Dec 2001
St Neots
Was looking at a 451, seemed to me that if it does I would'nt need the laptop if I interfaced the AIS engine to it?
Twister_Ken
31 May 2001
'ang on a mo, I'll just take some bearings
I've got the 555 combined with a Digital Yacht AIS receiver.
As far as I recall* it only shows the position of the AIS contact, not predicted course, but if you pull up the numbers, it gives the predicted CPA. Only played with in Lake Solent so far, not been used in anger.
*But I might be suffering brain failure, or maybe there's a bit more configuration to do in the menus.
Pete7
11 Aug 2004
Gosport
The Garmin 555 will give you "time to impact" plus yours and the targets course, but only if you have told it your destination which it needs to work out the two courses.
Learnt this the interesting way sailing from Gosport to Lymington. As we passed north of Cowes the AIS alarm went off warning of imminent death destruction and in less than 2 minutes. Looking around there wasn’t anything even close that could be considered life threatening. Then the GPS drew a red line from Calshot Spit area going south across our westerly track. Looking carefully we could finally make out the Red Funnel fast jet just making his turn off Calshot and lining up on us. With less than 90 seconds to certain death we altered course, the Garmin quickly computed the new course and that disaster had now been avoided so cancelled the alert. It was close but the Garmin saved the day, well almost, but you get the idea.
jimi
19 Dec 2001
St Neots
Hi Pete, do you mean its computed on CoG and SOG or versus bearing to waypoint?
I can understand the value of the former but the latter perplexes me?
Pete7
11 Aug 2004
Gosport
Hmm, I think it uses the data of speed and course from another vessels AIS to give a display of a possible collision. If one vessel alters course the plot on the chart plotter and the time to impact are removed or altered if the alteration isn't enough. So yes it must use COG and SOG for both vessels to arrive at this.
Twister_Ken
31 May 2001
I don't have a transponder, just a receiver, so I don't know where an AIS transmission gets its input from for sure, but as it's broadcasting lat/long it must at least be getting some from the GPS. Whether the rest is coming from log (water speed) and compass (hdg) or also from the GPS (COG and SOG) I don't know. On biggies, something is also working out rate of turn - again whether that is ship's compass or change of COG I'm unsure.
Anyone know?
jimi
19 Dec 2001
St Neots
The ship transmitting gives speed and COG, the GPS should give COG and SOG, it should then be able to calculate CPA and time based on these.
I've got a laptop program that does precisely that. However, I was hopingthat could dump the laptop anf use the chartplotter
KREW2
20 Jan 2005
Dorset
I have the small 180 Standard Horizon, connected to a comar AIS, and all the info is displayed on the screen. I can't see Garmin producing a chartplotter that can be connected to an AIS receiver, and does not.
Pete7
11 Aug 2004
Gosport
Ah, just been back over this thread and I have missed a piece of information out.
Our Garmin 555s is connected to an Easy AIS receiver. I spoke to Garmin at the Southampton Boat Show a couple of years ago and since they didn't have an AIS at the time they recommended the Easy AIS, so bought one as well as the Garmin. All very straight forward to connect up.
jimi
19 Dec 2001
St Neots
No problem, Pete, I understood that/ I already have got AIS running on a laptop whick gives full info. I had just wondered if the garmin gave anymore info other than "in 20 minutes the Bilbao is going to ram you"!
yoda
12 Dec 2001
Tamar river, Devon
Garmin and AIS
Is this any good, does it show projected tracks and CPA?
I have the 551 interfaced to a NASA AIS engine and i am fairly sure it just showes a target and when selected gives CPA etc. You can select the CPA range that activates the alarm and clasifies it as a 'dangerous' target (audible alarm and turns from green to red). I like it as I can just use the plotter in the cockpit without the laptop being on.
Yoda
