FullCircle
FullCircle
19 Nov 2003
Well, thats my reputation sort of in the clear then, a bit.Y ou can take back all the comments about your Postal comrades now then. /forums/images/graemlins/laugh.gif
Or perhaps I addressed it to Stingo, Durban South America and it has arrived in Europe via a Catamaran in Sable D'Olonnes and forwarded? Coincidence? You decide!
It is worthwhile doing a long term check against another quartz item,as mine differed by 17 seconds over 3 months, but it could have been the other piece of kit, or a share of the 2 inaccuracies.
The baro and humidity bits were pretty much singing off the same hymn sheet all winter, and the outside sensor showed no signs of distress having been perched on the roof of my shed all winter.
FullCircle
19 Nov 2003
Not so tome, even a caesium resonator has an observation adjustment in its programme. /forums/images/graemlins/grin.gif
The resonator is used as a passive instrument to calibrate the quartz clocks, usually at intervals of a few days; and it is estimated that the clocks calibrated in this way provide at all times the atomic unit of frequency and time interval with a standard deviation of ± 2 parts in 1010. The quartz clocks are also calibrated in terms of astronomical time and the results are compared for the period from June 1955 to June 1956. For operational purposes the frequency of the resonance was taken as 9 192 631 830 c/s which was the value obtained in terms of the unit of uniform astronomical time made available by the Royal Greenwich Observatory in June 1955. The value is being determined in terms of the second of ephemeris time, which has now been adopted by the International Committee of Weights and Measures as the unit of time, but to obtain the accuracy required the comparison must be extended over a long interval in view of the difficulties associated with the astronomical measurements.
Pinnacle
6 Jan 2006
Just goes to show what imminent matrimony does for you.............
/forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
CPD
20 Sep 2006
Hampshire
Well, thats my reputation sort of in the clear then . . . . . .
Well it was 5 minutes ago Jim ! /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
tome
28 Mar 2002
kprick
www.google.co.uk
That's because a caesium resonator drifts (abeit ver slowly). A gps receiver doesn't drift as time is one of the unknowns it is solving as part of the fix
If you had access to the clock, even a modest GPS receiver is capable of outputting time to an absolute accuracy of better than a micro-second without any drift
There is usually a delay in outputting time to the display as it is not the highest priority, but this is generally less than half a second and will not vary much
Hence, as I mentioned previously, gps is a very good instrument for rating onboard clocks
FullCircle
19 Nov 2003
I know, I know, but with ignoring the radii of the infinite allegedly straight line, there are no circumstances where time is an absolute, especially from any given point in space. Therefore, I propose that there can be no point at which drift cannot be said to be present. /forums/images/graemlins/tongue.gif
webcraft
8 Jul 2001
Cyberspace
www.bluemoment.com
[/ QUOTE ] - true, but to get UTC you have to deduct the leap-seconds (currently 9)
So UTC = GPS time - 9 sec
BrendanS
11 Jun 2002
Tesla in Space
The GPS signal contains the UTC offset, which allows the receiver to correct to UTC. However, as the UTC offset is only transmitted every 12 minutes or so, you'd better leave the receiver for 15 minutes after it first gets a fix after power on, to ensure it has received the offset signal! /forums/images/graemlins/grin.gif
tome
28 Mar 2002
kprick
www.google.co.uk
Sorry Webcraft, no cigar for you
The leap seconds are broadcast as part of the Nav message from the sats so the gps receiver automatically converts to UTC. You don't need to do any conversion as it displays UTC
Which is just as well as the current number is 14, not 9!
sarabande
6 May 2005
You are confusing Euclidean geometry with Einsteinian relativity. Across a time warp (think rubber sheet matrix with an indentation) any GPS system would have no difficulty in locating itself in at least two points in space, each using four degrees of freedom (x,y,z, and time).
Self referentially, a satellite always knows where it is; it's the perturbations of the Earth in heliocentric orbit that make it giddy and give out false signals.
tome
28 Mar 2002
kprick
www.google.co.uk
Brendan
The receiver should remember the leap secs so unless you haven't powered it up for about 18 months (roughly the interval between leap sec updates) it should work correctly right away
BTW, leap sec updates are always done midnight 30/6 or 31/12
