Bouba
The bill is already in the stratosphere ??in all due respect that's bull Bouba. It's your boat, it's out of warrantee, you pay for the bill, you ask for something, THEY do it and charge you for it!
Think of all the fuel you’ve saved. Every cloudThe bill is already in the stratosphere ??
Except I didn’t...my consumption was still high?Think of all the fuel you’ve saved. Every cloud
Well ask them to do it. You will be glad of it.While the boat is at their yard I won’t be interfering...it’s not fair to expect the yard to stand behind their work if they don’t know where I finished and they began
Could not have been.The bill is already in the stratosphere ??
On the top of the tank was the inlet and outlet of the engine and generator....the sender unit is just a hole..there is the filler pipe plus breather...plus some tabs to secure the tank to the bulkheads ....and two (?) screw plugs with some kind of handle on them plus some other tabs that I can’t identifyat last some progress!
odd they need 10holes on the top of the tank though!
each engine counts for two, sender another one, fill and vent another 2 that's 7, missing threeI could almost accept another vent on the other side. Still two missing unless ST was also available with twin engines or an Eber /webasto system could be fed from the tank and then we are almost OK.
V.
We are awaiting the new tank...I have no more information at present...I’m hoping it will arrive very soon..we were quoted 10 days for its fabrication...but is that ten business days? (there was a very long weekend break that’s just finished)...we just wait for that telephone callSo when is the expected finish date?
Hope it's soon.
Thanks for the update.We are awaiting the new tank...I have no more information at present...I’m hoping it will arrive very soon..we were quoted 10 days for its fabrication...but is that ten business days? (there was a very long weekend break that’s just finished)...we just wait for that telephone call
Yes...it had multiple corrosion spots all in the bottom of the tank...I will post some photos when I see it next...Thanks for the update.
Did the yard remove the old tank yet?
No need to rush to bankrupt yourself filling it with diesel!We are awaiting the new tank...I have no more information at present...I’m hoping it will arrive very soon..we were quoted 10 days for its fabrication...but is that ten business days? (there was a very long weekend break that’s just finished)...we just wait for that telephone call
Do you dose your tanks to keep the fuel dry etc?Yes...it had multiple corrosion spots all in the bottom of the tank...I will post some photos when I see it next...
Mixed bag .Stainless steel in most small ones and fibreglass in larger .They are mounted on frames with straps .Air gaps all round FWIW .Amarti would take you out to lunch look you up and down and decide wether he wanted to build a boat for you .Do you dose your tanks to keep the fuel dry etc?
Ive often wondered weather med boat tanks sweat more (except Itama obviously….they have special tanks no doubt)
Do you know if the corrosion started outside the tank or inside the tank?Yes...it had multiple corrosion spots all in the bottom of the tank...I will post some photos when I see it next...
