harvey38
I recall a post (but can't find it) about a company that cut and fit fuel tank inspection hatches, I'm in Ramsgate so recommendations would be appreciated
Pride comes before a fall JonathanWhat do you expect to find that your CAV filter has not already told you. Our fuel tank is vertical, it sits in a deep locker and the tank has a recess through which the mast fits. The tank is white gel coated fibre glass and I cannot see to the bottom of it. We fill our tank using 20l cans with the diesel purchased from standard roadside petrol stations. After over 20 years of ownership we have not once had a problem with questionable fuel.
Our fuel tank has no inspection hatch.
Jonathan
I agree. I put an inspection hatch on my fuel tank when I bought my boat 20 years ago and I have never used it. Now it's a source of leaking diesel if I overfill. Another job to do some day.What do you expect to find that your CAV filter has not already told you. Our fuel tank is vertical, it sits in a deep locker and the tank has a recess through which the mast fits. The tank is white gel coated fibre glass and I cannot see to the bottom of it. We fill our tank using 20l cans with the diesel purchased from standard roadside petrol stations. After over 20 years of ownership we have not once had a problem with questionable fuel.
Jonathan
It will allow the old fuel to be polished, part of a fuel sender and float to be retrieved, and forty years of detritus I can feel when dipping the tank to be removed.What do you expect to find that your CAV filter has not already told you. Our fuel tank is vertical, it sits in a deep locker and the tank has a recess through which the mast fits. The tank is white gel coated fibre glass and I cannot see to the bottom of it. We fill our tank using 20l cans with the diesel purchased from standard roadside petrol stations. After over 20 years of ownership we have not once had a problem with questionable fuel.
Jonathan
Here ya goThink it is Vetus who make round hatches with an expanding seal that fit a hole cut in the tank. Bit of DIY with a jigsaw?
Thanks but both tanks have 750l capacity and currently about 600l in each so I don't have the capacity to drain and polish, being stainless, I certainly don't have the correct cutting gear.
They have the cutter listed too. But, unlikely you have a drill that will turn slow enough to cut SS. Still, was just suggesting an alternative to getting a company in, likely to cost way more than the bits for DIY.Thanks but both tanks have 750l capacity and currently about 600l in each so I don't have the capacity to drain and polish, being stainless, I certainly don't have the correct cutting gear.
Would it not be possible to agitate the fuel and polish it?Thanks but both tanks have 750l capacity and currently about 600l in each so I don't have the capacity to drain and polish, being stainless, I certainly don't have the correct cutting gear.
Thanks for letting us know how YOU fill YOUR tanks, the make up of YOUR tank and that YOU haven't had a problem with questionable fuel. None of which assisted me with my original post![]()
Jonathan,But then in your parsimonial original post you mentioned none of this, you did not mention what YOUR tank was made from, nor why you wanted an inspection hatch (which if you read the replies - hatches are not mandatory.. We we're left to guess why you wanted to cut a hole, guess what the tank was made from - you expect too much - but many who start a thread are no different - beggars belief.
If you want help provide the fullest detail - and don't complain when someone takes the trouble to guess what you might actually want - its not their fault if they get it wrong - you made the omission.
Jonathan
Please don't get disheartened. His vibrations are probably low at the moment. We all get it.Jonathan,
I simply asked for some information, the reasons for why I wanted that information is irrelevant in the first instance.
Others posted suggestions for which I am grateful so it was only polite to explain why I need hatches cutting, there was no need to guess anything, if you were genuinely interested then ask rather than a rather abrupt opening line. I made no omission, maybe you made an assumption!
Your ramblings however provide no useful information as to where I may find the posts I refer to nor a possible contact that may travel to Ramsgate.
I hope you have a good evening![]()
See post #1In post 6 I showed a frame for an inspection hatch I used on a GRP tank. The same type of frame can be used on a stainless steel tank which tend to be quite thin thus can distort and needs a stought frame to correct the distortion.
The hole can be cut with a small angle grinder with a cutting blade and very little accuracy is required in te rectangular hole in the tank.
If you are going to polish the fuel after and crud made by the cutting would be filtered during the fuel polishing process.
I know as I have drilled and cut into my steel fuel tank and filtered the swalf out later.
If you don't have the skill any competent DIYer could do the job or a local engineering company
Where are you located a w may be able to suggest a local company you could approach of a skilled forum member. Not me asI an not in the UK
