Fuel polishing
alancollins
28 Mar 2008
Has anyone used a professional diesel polishing company and what sort of costs are involved? My boat is ashore in Southampton and has a 48 gallon tank.
I had my tanks cut into with access hatches installed , three per tank. Then the fuel removed, tanks cleaned and then fuel polished. It cost me around £700. I’m in Southampton .
A Dipper is not much more expensive and means continually cleaned fuel. Why waste money on a one-off clean?
About 15 years ago, I had a fuel problem, 40 year old boat, no inspection hatches. I could barely get any fuel out, grp tanks, no inspection hatches, so I took a hole saw to the top of the tank to investigate. I found 2 internal baffles, so 3 compartments, So I cut a hole into each compartment. What I found was a disintegrating wooden handled wire brush!! Must have been left in when they bonded the lid on the tank. But also, on the bottom, a thick layer of brown sludge. I made big inspection hatches, 300mm square, and new clear lids. Once scrubbed and cleaned and refilled I could see the clear red liquid and I could see the bottom.
Since then, my view is that diesel tanks need manual intervention every 10 years.
My point is, dependent on age of the boat, fuel polishing or a dipper, will just not be enough. It may need a proper scrub out.
(as an aside, this thread started by Alan Collins, I have a mate of 30 years or so, Andy Collins, he has a brother Alan, who I have never met, but that Alan Collins lived next door to Fred West and went there for a BBQ on the patio!!!)
I cleaned my tanks every three years, but the design of the system meant almost no contamination.
I've fitted a Dipper on my current rebuild with a brand new tank so should never have sediment.
Even on a contaminated tank continual draining of the Dipper will eventually clean the tank. It will also vastly extend filter life!
