jsl
On our engine we have a CAV type filter with aluminium bowl and off-centre drain plug. The bowl is big and more or less rests on the gear shift cable which passes beneath it. This makes getting it off to change the filter a real bore. Could I just swap it for a shallower bowl? Or is there some arcane reason for the present arrangement? I realise that I would also need a shorter through-bolt (or whatever it is called). And presumably a glass bowl would be a bad idea.
