psousa
Hi!
I know this is a big subject here but I didn't find anything about issues related to high amp/hour consumption, so here I am.
The equipment:
Vitrifrigo C130L DX 06
Danfoss BD35F
I have this unit controller since March 2018: https://www.ebay.com/itm/273083414325?ul_noapp=true
The unit controller on the picture is the old one. (Did you noticed that wires? The blue one with the black and the brown one with the red? I kept it on this new controller but it's starnge! Usually the brown is the negative!)
Since last weekend, when my compressor starts, the panel shows a lot of amp/h consumption.
In the past was consuming only 10-11amps and steady. Now moves from 8 to 27 (I saw 27-28amps few times and 30 once) very fast, which is strange.
I've noticed this because it blew up me 2x10a fuses from the panel. The first one I didn't care. But after the 2nd one on the same weekend I was looking around to the details and it was when I saw these amps on the panel!
After that, checking around, I found the fan is dead (but the unit controller has 12v on F connector). I already ordered a replace one and I'm using external ventilation now.
But the high consumptions keeps moving around (up and down all the time while compressor is working).
The unit controller is new (March/2018).
Fridge is cold enough and the ice compartment is frost.
Thermostat seems to work in spite of I can't see big differences regarding it's position but I didn't tested it really well (just the click on and off). Now it's always on the lowest level, just touching the switch off trigger and the ice compartment is frost, so it's good enough to me.
Tested for one day without the resistor on the thermostat circuit and it defrosts. Amp/h was lower but unsteady anyways and with high peaks, also.
I made the jumper test on the unit controller (connected pins directly to jump the thermostat). The behaviour is the same: high amp/h and fluctuating.
Besides the unit controller replace in March (I did it by myself), nobody touched or changed anything on the system.
Suddenly, last weekend, I had this issue: just the amp/h, everything else seems to be the same.
I don't know if it's related with high temperatures we had, but I don't think so.
I just would like to ask your help pointing me to the right direction. Where should I start? Compressor itself?!? :-O
Unit controller? (I've contacted the seller and he told me it's not possible and considering the symptoms could be the compressor itself). Everyone says the compressor hardly fails, but now I don't know where to start.
Thank you!
![](/proxy.php?image=https%3A%2F%2Fthumb.ibb.co%2FmWGAPo%2F20171231_050920645_i_OS.jpg&hash=067dc2c36bf1f7c7cb0139912e06bf03)
The equipment:
Danfoss BD35F
Thank you!
![](/proxy.php?image=https%3A%2F%2Fthumb.ibb.co%2FkyqgVT%2Fimage2.jpg&hash=8c328f4f0f6836f743806afd4307a745)
![](/proxy.php?image=https%3A%2F%2Fthumb.ibb.co%2FhssH4o%2Fimage3.jpg&hash=03d9c0172f958c0c3528c4b69016a659)
![](/proxy.php?image=https%3A%2F%2Fthumb.ibb.co%2FfNbc4o%2Fimage4.jpg&hash=3f96e86973693cd1535bdd6a83021c0f)
