Four strand laid line.
john_morris_uk
3 Jul 2002
At sea somewhere.
I bought some new mooring lines the other day in Spain. Two things were odd. Firstly the line wasn’t sold by the metre but by the kg. Second it turned out to be four strand laid line. I didn’t notice until I got back to the boat and started to whip the ends. I’ve never seen four strand before…
Wansworth
8 May 2003
SPAIN,Galicia
The fishing use a great deal of line and it’s usually sold by weight ,probably for yachts not such long lengths are required and it’s posher stuff?
Kukri
23 Jul 2008
East coast UK. Mostly. Sometimes the Philippines
The Youth of Today!
When did you start sailing?
All rope was sold by weight in this country until artificial fibre came in. Four strand hemp was common and used for shroud lanyards. I am speaking of the 1960s.
sarabande
6 May 2005
The Youth of Today! When did you start sailing? All rope was sold by weight in this country until artificial fibre came in. Four strand hemp was common and used for shroud lanyards. I am speaking of the 1960s."
Some of us can remember when rope for yachtsmen was sold by the fathom, and the measurement was the circumference, not the diameter...
Kukri
23 Jul 2008
I remember being confronted with the choice (in descending order of price for the same circumference in inches) of four strand tarred hemp, yacht Manila or No.1 Manila. That was 1969 in Clarke and Carter’s chandlery in West Mersea, just east of the Yacht Club, and all three were sold by weight.
I bought the cheap stuff.
En France, dans ces hours-la, l’on mesurait le longeur et le tirant d’eau d’un bateau en pieds, et les cartes indiquent le profondeur de l’eau en brasses.
3 Apr 2022
Four strand rope is relatively common in natural fibre ropes such as hemp. It is a rounder rope, with less stretch than three strand, hence it is called "shroud laid" rather than "hawser laid". It is a slight oxymoron having four strand in nylon, unless they required a very strong rope with less stretch than a conventional three strand nylon. Normally four strand ropes are laid up around a central core or heart rope (in effect four strands plus a core). In the case of hemp ropes this core is often sisal. If you are making up dinghy or boat fenders you can remove this core rope and work in a flexible wire rope so that the assembly can be fastened to the boat by means of two rigging screws on the transom. It is also useful feature for disguising electrical cables feeding decorative lamps hanging from a ceiling etc.
Spirit (of Glenans)
28 Mar 2017
Me; Nth County Dublin, Boat;Malahide
So the OP will have just as little stretch and shock-absorbing capability in his new mooring lines as he had in his old repurposed lengths of halyard or sheet line
