Four strand laid line.
Star-Lord
25 Jan 2020
I bought some new mooring lines the other day in Spain. Two things were odd. Firstly the line wasn’t sold by the metre but by the kg. Second it turned out to be four strand laid line. I didn’t notice until I got back to the boat and started to whip the ends. I’ve never seen four strand before…
They sell lines by weight in Tunisia. It's all white and very cheap.
john_morris_uk
3 Jul 2002
At sea somewhere.
Four strand rope is relatively common in natural fibre ropes such as hemp. It is a rounder rope, with less stretch than three strand, hence it is called "shroud laid" rather than "hawser laid". It is a slight oxymoron having four strand in nylon, unless they required a very strong rope with less stretch than a conventional three strand nylon. Normally four strand ropes are laid up around a central core or heart rope (in effect four strands plus a core). In the case of hemp ropes this core is often sisal. If you are making up dinghy or boat fenders you can remove this core rope and work in a flexible wire rope so that the assembly can be fastened to the boat by means of two rigging screws on the transom. It is also useful feature for disguising electrical cables feeding decorative lamps hanging from a ceiling etc.
This definitely has no core.
boomerangben
24 Jul 2003
Isle of Lewis
I was beginning to think this thread was going along the lines of the Yorkshire sketch (Brooke-Taylor/Cleese/et al) and am waiting for “when I was a lad you had to pluck t’tails of a yearling unicorn, spin them in moonlit glade the day after Micklemass….”
Neeves
20 Nov 2011
Sydney, Australia.
Strength is determined by weight, the amount of raw material/cordage being used. Why would you expect anything else?
If you had 10mm steel tube and could make it into a chain you would not expect t it to have the same strength of solid wire.
Don't believe me
Ask Marlow.
Jonathan
SaltyC
15 Feb 2020
Yorkshire
I started sailing in the 60s, and I certainly remember fathom charts and still have some in use. I also remember when rope was sold by its circumference. However I didn’t ever buy rope in the sort of quantities or sizes that needed to be weighed in those days!
DITTO, however as I was but a mere 'boy' I never bought the rope so cannot comment on how it was sold.
