pmorris
Just a warning.
I had to remove my stainless steel fitting on the mast, which houses two halyard sheeves and the forstay connection. The only thing holding it there was four stainless set screws tapped into the 3mm thick aluminium mast section. One of which when it was unscrewed half a turn, just pulled straight out because it had corroded the mast.
I don't know about anybody else but it didn't seem good enough too me. So I've had SS plates rolled to the same curve with nuts welded to them so I can now sandwich the mast section between those and the fitting. Does this seem ok or would you suggest another way?
Somebody's told me theirs a paste that you should put on the fittings to create a barrier inbetween the mast and the SS. Does anybody know what its called and where I can get some.
Cheers Paul
Cheers Paul
