KellysEye
The wave height in a force 10 is 9 to 12.5m the waves look nothng like that.
As for the lack of breaking waves, could the point of sail have had something to do with that? He was sailing primarily away from the waves. (Actually a question because I have no clue).
It certainly helps make the case for continuing to sail downwind, rather than heave to or slow down, IF got lots of searoom (or able to get into sheltered water before approaching harbour, as in this case).
But I am still amazed that in a full Force 10 one could sail with hatches wide open and no need for lifelines. Cross waves tend to break into the cockpit, and/or the nose diving into the back of a wave sending solid water back. Particularly if the boat is a submarine type as some have suggested.
Plus I would have imagined that in F10 you would be sailing fast under bare poles (people often start to consider ropes to slow down in these conditions, which had mixed results to say the least in GGR), rather than part reefed genoa.
Certainly a fun ride by an experienced sailor, but doesn’t feel like a representative full Force 10.
Don’t know about F10.
At 12.40 today my crew and I stepped off a Nic 55 in Woolverstone aboard which we had sailed from the Hamble at 0800 yesterday.
At all times before during and after our trip the weather forecast was for Beaufort F7, F7 and F9.
There were no wrecks, and nobody drownded, and nothing to laff at at all...
...There were no wrecks, and nobody drownded, and nothing to laff at at all...
I wasn't convinced it was a Force 10 (though more than enough for me).
Before he set off he said, IIRC, that the island's met station was showing 45kts gusting 55kts. That's F9, not 10, and the station appeared to be at the top of a hill, where wind speed would be higher due to (a) elevation and (b) accelerating over the hill.
When he was running he said IIRC that the boat was doing 6 1/2 kts, which meant the wind was 40 to 42 kts (presumably added boat speed to apparent wind speed). That would be F8 - F9, even assuming it was steady rather than a gust.
I would not expect to be able to stand up without holding on in a 35' boat in a F10, let alone operate a camera. I certainly wouldn't expect to be able to clearly record speech into a microphone.
For me the most alarming aspect of it was heading towards a lee shore with only limited openings (and those between low lying islets that would be difficult to see if the viz closed in). It wouldn't take much in the way of mechanical problems, or injury following a fall or whatever, to make that lethal.
Years agoI recall a harbour master preventing a yacht putting to sea in the face of bad weather,the yachtsman wanted to test their heavy weather stuff.
A few years ago when my boat was kept in Mayflower Marina, whilst chatting I was told by one of the crew on a visiting Clipper training yacht that as part of the program they go looking for bad weather, out in the Western Approaches ?
And by the looks of it planning a solo trip to Greenland, so getting some more heavy weather experience isn't a bad thing.Lets not forget he's an experienced skipper on his own boat.
I'd disagree with you. He has undertaken a number of mid winter passages from Norway to Shetland! I'd consider those passages had far more risk.Guy's proper nuts!
Anyone here even consider doing that?![]()
