25931
WhenI was in mytI don't know why some of you people even cruise in Greece, you seem to hate the way the country is run so much. And often without fully understanding what you're even talking about. ALL Greek documents require your father's name, some also require your mother's name. The reasoning is simple once you understand how children are traditionally named here. The first born son is named for the father's father. The first born daughter is named for the mother's mother. The second born son is named for the mother's father. The second born daughter is named for the father's mother. Not only is this traditional and respectful but it also helps to preserve ancient christian names and avoids the stupidity of people called Zara and Zac (or worse).
That of course means that in a family with a surname of (say) Kyriakis, if the grandfather is Georgios Kyriakis then his son's firstborn son will also be Georgios Kyriakis (affectionately known by the diminutive Georgaki). Since Greek families often live together at the same address it's confising having two Geogios Kyriakis at the same address - but by including the name of the father it's possible to tell them apart. That your father died 50 years ago is neither here nor there, the system here requires father's (and sometimes mother's) names to be sure they know which Georgios Kyriakis you are. If you want to be here then learn to fit in - you are a guest here and you have to change to suit the Greeks, not the other way round.
Greece has not (to my knowledge) refused to vaccinate foreigners. The need for an AMKA number (which is like the UK NI number) is because ALL health services are keyed on the AMKA number (just as they're keyed to the NI number in the UK). As I understand it the issue of temporary numbers is taking some time because they need to ensure that they are easily identifiable in the future as being vaccination-only numbers and are not able to be used to access regular Greek healthcare. As I understand it the AMKA system (which really is just a number) was never designed to have such restrictive numbers issued - that's the problem.
And don't you dare accuse Greece of bribery and corruption with the Greensill scandal rumbling away in the UK. People who live in glass houses.....
When I was in my teens my grandfather who lived with us and had the same name was JG Senior, my father JG Esq.and I JG Jnr.I don't know why some of you people even cruise in Greece, you seem to hate the way the country is run so much. And often without fully understanding what you're even talking about. ALL Greek documents require your father's name, some also require your mother's name. The reasoning is simple once you understand how children are traditionally named here. The first born son is named for the father's father. The first born daughter is named for the mother's mother. The second born son is named for the mother's father. The second born daughter is named for the father's mother. Not only is this traditional and respectful but it also helps to preserve ancient christian names and avoids the stupidity of people called Zara and Zac (or worse).
