ST840
Is this a thing?? I heard from somebody that they are pushed under the boat then float up. Then you pull them with an angled pole so as to clean the crud off the hull?
What was the issue with it then?I bought one , tried once , never bothered again. Might be ok on a round ish hull though.
The thing you mean is the Scrubbis I think:Is this a thing?? I heard from somebody that they are pushed under the boat then float up. Then you pull them with an angled pole so as to clean the crud off the hull?
I have been using the one I made for over 8 years now allowing a scrub from the pontoon. Made from a length of jib reefing foil (from a sailboat, found in a skip) bent to a long curve with two articulated scrubbling brushes and a fender on the end. Mine is made for a round bilge hull but I am sure you could shape the pole to suit other hull shapes.Is this a thing?? I heard from somebody that they are pushed under the boat then float up. Then you pull them with an angled pole so as to clean the crud off the hull?
Www.solocoastalsailing.co.uk
Fancy making another ?I have been using the one I made for over 8 years now allowing a scrub from the pontoon. Made from a length of jib reefing foil (from a sailboat, found in a skip) bent to a long curve with two articulated scrubbling brushes and a fender on the end. Mine is made for a round bilge hull but I am sure you could shape the pole to suit other hull shapes.
are you thinking of btizoIs this a thing?? I heard from somebody that they are pushed under the boat then float up. Then you pull them with an angled pole so as to clean the crud off the hull?
No good for shaftsWhen filling up last week, I came across a hull wash system local to me in Stockholm. They say it will take over 40 foot, and certainly seems scalable. Could be a good business for the UK!
A brizoIs this a thing?? I heard from somebody that they are pushed under the boat then float up. Then you pull them with an angled pole so as to clean the crud off the hull?
Tgpo. A brizoare you thinking of btizo
