mhardie
hi all. Dose anyone know the best or easiest way to check aligment and adjust with a flexi coupling thanks mhardie
See you had a tremendous reponse! but it is better sometimes to get no reponse than get poor advice!
One point I can tell you from experiance is beware some couplings if they have been taken apart only assemble 'one way' and it is easy to assemble them the 'wrong way'.
I learnt from assembling my flexable coupling type shown below.
If your engine is already in position and shaft assembly the end of your shaft coupling flange should 'mate up' in line easily with you flexable coupling flange when the two a brought together, ie you should not have difficulty in fitting the bolts.
Hope this might help but I do not know what type of coupling you have.
Mike
Impressively clean machinery and surrounding area !
I now have a Centaflex M (Quietlife) but that's another saga....
I
Do tell!
withthe R&D type one bolt head is slightly domed, use this one for the witness at 90 degrees, might need a packing spacer to get a good feeler reading.
