MapisM
LOL, no worries, you actually missed Deleted User's engines size as well, since they are 22 rather than 24L...Sorry MapishM— forgot size of your engines ?
183 is the magic number, when it comes to Mercedes-derived V engines.
In fact, before replacing it with their 2 liters/cylinder series, MTU called that block (which is exactly the same used by MAN) "183 series" - which stands for 1.83 liters/cylinder.
So, V8/10/12 are 1.83*8/10/12 respectively.
Mind, your engines do NOT follow the same rule, because in the 6L the bore is the same, but the stroke is longer.
Back to the point, unfortunately I have no idea about the fuel burn of my engines below 1000rpm, which is the first "step" reported in actual tests - and which pushes the boat at 9.5kts, burning 42lph.
But since 9.5kts is already a fair bit above D speed, I would expect the 42lph to at least halve, when running at tickover rpm, which is good for 6 kts or so.
In fact, I'd be happy to bet that also TH's Nordie burns fuel like there's no tomorrow at 9kts, with a HUGE difference compared to her normal 10 lph @ 7kts.
I will soon stay in the US for a couple of months, and I might decide to burn some bucks into Floscan gauges, if available at decent prices... And if I will, after installing them I'll be able to update with some true numbers! :encouragement:
