Nautical
Just logged on after quite a bit of time away and Oh look "trawlers!"
Just from my perspective and I have a dog in the fight of course but nevertheless.
If I were just going Med cruising and don't expect to be too pushed about weather and have time to sit it out if needed and want in and out of the boat say 5 - 10 years then I would forget the whole Trawler thing and just buy something like JFM's Sq 78 , pretty much the perfect med boat and will do absolutely everything you could ever want and even handle a bit of roughty toughty stuff so long as it doesn't end up 20 footers and 50 knots howling off the beam for 24 hours.
If however your looking for..... "well sod it its blowing 6's and 7's but who cares we're off anyway" then a well founded SD LRMY is going to be the better bet which ever way you look at it, you can argue the points of handling quartering and beams seas etc till the cows come home but if your intent is to be regularly sailing for couple days at a time non stop in that sort of stuff the SD heavy brigade is just going hang together a lot better . Its not so much even the design or under water sections that make the difference as we all know a P hull has many advantages in certain conditions, its the sheer weight of construction that counts . Take say an ORY 700 series , fully loaded that's in the region of 70 + tons (and usually with smaller engines ) whereas a Princess or other is around 30 tons lighter (but with heavier engines and trans) . That extra 30 tons which when you think about it is an enormous weight difference for the same LOA and can only come from the weight of construction, lamination schedules, joinery and runners and stringers etc .
When you're getting beaten up hour after hour , day after day , year in year out for 20 years (ok an exaggeration but you get the drift) your P boat is in need of serious attention and the interior is likely fire wood at that stage and sounds like its coming apart at the seams in a big sea.
Then there is all the redundancy built in. How many P boats have not just a second back up fresh water pump but a third as well both in 24 v and 220V. Lose a FW pump and how do you flush the heads or take a shower? , or diaphragm pumps instead of a macerator pumps which a few bits of kitchen roll has knackered your pooper . Back ups to the AC units, secondary pumps for the reverse cycle separately plumbed so if it all goes south with the first you can come back on line with the second and back up units .
Pull fuel from any tank to any tank via any machinery through fuel polishers , back up hydraulic PTO's from the genset to run the winches and stabs if you lose one or both from the main engines .
And on it goes (and so does the price accordingly) .
Other thing to consider is residual values, a 20 year old Nordhavn , Fleming, ORY etc is going to be worth significantly more than a production P boat which was probably near to the same selling price when new but is now worth half of that and in some cases that's even wishful thinking .
Take a swipe at a pontoon with a 70' SD / D heavy weight and you'll probably demolish the toon and sail off thinking I wonder what that bump was , in a P boat its get your cheque book out and book a slot in the travel hoist jobbie.
Horses for courses as they say , P boat with Vector Fins or similar for Med boating and the odd once in a while lumpy stuff and SD / D if you intend on doing regular serious stuff or heading off into the wild blue yonder with no marina support for 1000 nm.
