rotrax
Why, I wonder, would a Frenchman furl his flag? Don't get that.
Still, evidently a respectful gesture.
Same reason the Lights on the Eiffel Tower were turned off - a mark of respect and sadness.
This is where I am confused, the government updated their advise yesterday specifically for this event, it says:From the Horses mouth, the RNSA...
Half-Masting Procedure
For those of you afloat, you would wish to be aware of the following guidance regarding flag etiquette during the period of National Mourning.
Flags flown at half-mast are to be flown with the top of the flag positioned two thirds of the way up the pole/mast/halyard, but not less than one flag breadth from the top. Flags are not to be flown at half-mast from flag poles that are greater than 45 degrees from the vertical. In this instance either a black cravat or ribbon is to be added to the top of the flag at the hoist or the flag is to be removed. In order to show respect, when flags are raised, they are to be raised to full-mast and held for 2 seconds before being lowered to half-mast and secured. Similarly, when lowering the flag, it should be raised to full-mast and held for 2 seconds before being fully lowered. Flags flown permanently are to be lowered and raised again.
Once routinely flown flags have been half-masted, they should be flown 24 hours per day until further notice. This directive supersedes single service flag protocols.
Flags will be flown at full-mast at all locations from the time the principal proclamation of the accession of His Majesty the King is read, until the regional proclamations have completed. Exact dates and times will be notified by the Palace, but is antcipated to be for 24 hours from 1100 on 10 September.
Ensigns will return to full mast from colours the day after the funeral.
I'm not sure where the confusion lies, or where anythng has been updated specifically for this event (because I don't believe it has).This is where I am confused, the government updated their advise yesterday specifically for this event, it says:
On poles that are more than 45° from the vertical, flags cannot be flown at half-mast and should not be flown at all.
So who is correct?
Maybe I am overthinking this but my view is: looking at institute of flags I always thought they were the go to place for flag etiquette.I'm not sure where the confusion lies, or where anythng has been updated specifically for this event (because I don't believe it has).
The quote I posted in post #20 is quite clear.
This is backed up by the advice from the Institute of Flags.
" Flags cannot be flown at half-mast on poles that are more than 45° from the vertical, but a mourning cravat can be used instead (see below)."
Therefore if a cravat cannot be added on a +45' pole then the flag should not be flown at all, (ditto on short yacht staffs.)
I made up some cravats, in-line with the institutes views.
gov.uk issued some guidance, this was edited 8 or 9th this month, specifically for this event, did not include any reference to cravats, indeed said if you cannot lower the flag do not fly it so I didn’t fly it.
The institute mentioned that the proclamation day ended 8.00 am the day after the proclamation. Gov.uk says it’s 13:00.
No major deal, mostly over now but there is inconsistency amongst different organisations as I guess this hasn’t been experienced for some time.
Regardless, it’s fascinating watching the proclamation procedures, so much history!
That’s not mutiny ….. it’s TreasonProbably mutinous to suggest we do this more often in order to gain in familiarity with the proper drill, so I will not do so?
I went for the option of a cravat, although my naval service was many years ago I felt it was appropriate to make the effort. Mind saw very few boats this afternoon having any regard to any attempt to show their respect through half mast and ours was the only cravat I saw, and that was in a naval port.As far as I have seen all opinion Inc the Institute of Flags and the Royal Navy is unanimous that cravats are the correct procedure with those short or angled staffs that cannot manage a true half-hoist. For certain, if you can't arrange a cravat then the flag should be removed.
Because he has not filled in his E 1331 & does not want the non existent BF to hassle him.Why, I wonder, would a Frenchman furl his flag? Don't get that.
They all have black ribbonsShouldn't the union flags lining the Mall have cravats on?
