Fixed the horn
tcm
11 Jan 2002
Caribbean at the moment
I seem to remember asking for a decent waah horn on this current boat, but the thing failed after a short time as did the chromy one on the previous boat, so i continued to use manual prarp prarp handheld air horns at 6ish quid a go from the boat shows. Mind you, the manufactureers did fit some other stuff i didn't ask for at all, including a 2hp compressor which um seems a bit excessive for blowing up a towable banana, or er possibly blowing dust off the engine.
Final warranty list came around so heyho let's put it down that the horn doesn't work. On the wiring diagram it seems to share the same relay switch as the compressor as it is says compressor/horn, i told the little man came round. He took apart a few junction boxy bits for a look, then goes down in engineroom for a fiddle about, eventually asking me to try the horn - and he's fixed it! Hurah, and about time too, but i bet it will fail again cos it always does. So this time I insisted he showed me what's what, and he too seems keen to show how he has fixed the infernal thing. He turns on the compressor on to get about 2 bar in the tank, then opens a valve and ahem er that's what powers the horn. Sheesh! It seems that several hundred quids worth of air compressor is there merely to power the horn. Cripes. Mind you it is quite good and you can adjust the pressure and make it moo and waah very loudly up and down annoyingly.
So, with partially busted anchor (another story) in Monaco I used the horn when reversing across the fairway. I think I was fairly obviously reversing, but another smaller boat appeared and sounded his horn once quietly to ahem Oi indicate his presence as he wanted to sneak up the channel behind me. Oh no you don't matey - three times loudly WOOOOM WOOOOM WOOOM very massive-shippishly such that the other boat stopped dead, got all confused and changed helmpeople and it was clear that none of them had much of sound signals, hehehe. The owner and wife clearly felt that I had been using the horn for not much reason as with a car. I would like to say that i stared at them silently through designer sunglassess as they eventually started to move again past out bows, but I am afraid I couldn't resist shouting down attem that three hoots means engines in reverse, you wassocks, look it up in a book, or get a proper skipper. Thus, already hopelessly out-horned and now conclusively out-boatiefied, the other boat continued into the marina in embarassed stony-faced silence, their sunny afternoon afloat rather spoiled by a smartarse git with a fully-charged massive air horn. Which i suppose must be the primary aim of a massive air horn in the first place.
wakeup
5 Mar 2002
Cote d'Azur
Best use of a really lound horn is to surprisre your lady guest when they are sunbathing front down with their bikini straps undone!!!! Watch them leap into the air with their puppies on show for all /forums/images/icons/cool.gif
longjohnsilver
30 May 2001
Anchor? Bully!
How do you get a partially busted anchor, does that mean you've now only got half an anchor, or is it bent doubleor mebbe part of it's been left on the seabed?
Now you know how your horn works are you going to honk at everyone who gets within 100 meters or so. Come on shove off, don't you know this is my bit of water, pillocks. Maybe you could use it as the early morning alarm call for all Antibes, expect they'd all love to be woken by your honking, would certainly beat seagull cries.
tcm
11 Jan 2002
Re: Anchor? Bully!
the partially busted anchor is a result of puting it up and down a lot, then it goes v slowly, untill you fill up the 3 litre gearbox with erm 2.75 litres of oil. Later, the skipper on the boat next to us with the same model who explained that it is lectric not hydraulic got all blimmin wurrid and started doing the same. Seems they are supplied dry but never filled with oil, and hence need a new one after three years.
wakeup
5 Mar 2002
Cote d'Azur
trying to think of a resposte involving dodgy nautical terms that can be used a la double en tendre (SP)?
But no such luck
ccscott49
7 Sep 2001
Re: Anchor? Bully!
Burnt anotherbloody anchor winch motor out!!! This one only coast £120 secondhand, thank goodness! i may just replace the whole bloodything in the winter, with a new vertical one!! I'm getting royally fed up with replacing motors!
