Surfacesub
Active Member
To answer your questions MapisM:- You may be correct with regard to the instrument origins. I merely mentioned this option to give you more choice, it was one I stumbled over when looking to replace my existing aircraft gauges which are too large for the helm panel. I also needed an adjustable alarm point output contact, and therefore I thought the Cruzpro delivered. Not being a dual application gauge (space limitation) the jury is still out.
I seem to remember the engine manufacturer specifies the point at which one measures the EGT in the exhaust tract and the corresponding full load temperature. Further down stream and inertial influances cick in. Debated above! One can find this design location difficult for a retrofit but once you find this max. value, under ideal conditions then wherever the sensor is located, all you need to be aware of is changes to temperature outside your preset limits. I'm sure this is your thinking.
You may have already stumble over the proprietary EGT alarm only. One single and the other dual engine.
I personally now like the idea of hi/lo temp. sets because if the hardware cannot be mounted at the helm then the audio alarm output contact is more than adequate, given the fact that early boats don't even enjoy this feature.
No, sorry, no personal experience of either components. In hindsight perhaps my contribution here is an error, the topic is at present causing consternations, so I couldn't resist offering you what help I could!!!! Good luck.
