Portofino
Moving on .
Chris what kit are you fitting ?
Selling it to you?You are not selling it to me.
What boat is that ^^^ who’s done that ? out of curiosity.
What boat is it ps ?Selling it to you?
When you don't even believe what I'm reporting based on first hand experience?!?
You're having a laugh.
But don't count on me to satisfy your curiosity - or to add anything else, for that matter.
Don't worry anyway, 'cause an Itama she ain't, obviously.
In fact, I'm pretty sure that all those who bought her or any other models of the same builder would rather run than walk away from toys like yours.
it’s not OEM .Selling it to you?
All I am going by is the pics .Not party to any conversations.Don't stop PF, tell us something more about that boat and her builder.
You obviously know better than myself - after all, I only spent a couple of hours onboard with her first and only owner, so what do I know?
Apropos, that guy was NOT selling the boat when I met him, he showed no signs of mental disorder whatsoever, and had worked for 30+ years as engineering consultant in redesign of chemical plants whose complexity is a multiple of what you can find even in superyachts.
So, since you are so sure that he was telling me porkies about what was done (or not, in the case of the exhaust) on the boat throughout her life, maybe you can explain me also his reasons for lying.
I'm not holding my breath on the possibility to learn something new from you, but as they say, life is full of surprises...
Do you possibly know if those temperature are in F or C?Guys enquiring as they are a tad high.
They are F , post turbo .Do you possibly know if those temperature are in F or C?
If the former, the numbers are well within specs - and very similar to those of my V8s, in fact.
But if the latter, I would call them through the roof, rather than just a tad high.
I'm saying this assuming that the probes are after the turbo, as it normally happens when retrofitted to these engines.
If before, aside from not understanding where and how exactly they installed the probes, I never came across any comparable data, so I can't judge.
They still sound pretty high, but maybe not as outrageously high as if measured post-turbo...
If the numbers of the previous 4 channels gauge are in F, they are fine.EGTs 550/560;*C ….I think pre turbo as OEM .
Sorry no clear pics ( Yet ! ) but iam pretty sure they are before the turbo on that pic of 20 cm L long pipe between the manifold and turbo .They are underneath tucked away .I will try and get a pic next visit , camera phone width permitting ?If the numbers of the previous 4 channels gauge are in F, they are fine.
Low 800 F might still be ok at WOT, but it was indeed a tad high at cruising speed - i.e. under 2000 rpm, as in previous pic.
Ref. your Celsius numbers, which are above a thousand in F, as I said I can't judge if they are pre-turbo.
But out of curiosity, do you know where exactly the probe is, and possibly have any photo?
I'm not familiar with inline 6 engines, but in any V engines that I've seen I couldn't figure where to fit a pre-turbo probe.
another test is remove the screw and start the engine:
if you flood in seawater, its on the jacket
if you suffocate on exhaust fumes, you're fine it's all the way through...
just undo the bolt and push a screwdriver in if it goes all the way in, you're fine. Somehow still doubt it.
and to make things worse, you said there are 4 of these holes in EACH pipe, or one on each?
V.
