Rohorn
Hi ....I posted a while back asking forumites for advice /experience with biggish inverters. I said I wanted to run a wet and dry vac on board, eventually a micro wave, or SWMBO was gonna quit. My thesis was that by using a vac with variable speed control, I could cushion the start-up surge and get away with a 1.5 kw inverter.
While briefly in UK, bought a Skytronic 1.5kw (alleged surge to 3kw) mod sine wave unit from TLC for 234 pounds including vat, which, in haste, was the best price I could find. Thing looks OK, but spidery font used on label betrays oriental origin.
OK, the beast (the inverter, not SWMBO) is now downstairs in my garage hooked up with 25 mm section cable to 4 x 110a/h leisure batteries and a serious charger (its on wheels) to simulate my diesels running.
The results are as follows.
1) With 1000 watt miele variable speed vac, cautiously switched on at 300 watt setting.....bad hunting, oscillating amps consumed, clearly not happy. Same with all intermediate settings
2) Same vac, brought up to full speed..... smooth and nice, consumption 5A at 230vac , and 80 amps at 12v.
3)) take deep breath, switch on miele vac set at full speed. Perfect, momentarily showed 100amps, then back to 80.
4) Plugged in new 1300 watt vac, no vario.....perfect, settled at 100 amps dc and 6 amps ac.
5) Plugged in old 8oo watt micowave, rated at 1050 watts draw....perfect. 80 amps dc. Made nice cup of hot Bovril to simulate life aboard.
6) Plugged in ghetto blaster...pretty horrible on LW MW and SW, but FM not so bad, but still miserable. Almost the same when GB is plugged into regular mains, but with inverter running nearby, so there is rf as well as mains spikes.
First Conclusions :- my thesis that a variable speed control would allow me to use a minimally sized inverter was rubbish. The thing works anyway. I suspect that more elaborate microwaves with microprocessor controls will not work, seeing what happened with the vario speed vac and the ghetto blaster.
Life expectancy? Reliability at sea? Your guess is as good as mine
Hope this is useful.....Cheers....R
