ashtead
One advantage of the stack pack is it tends to be far quicker to drop and while care is required as to the direction you are heading it does mean you can often motor sail up to mouth of river ,make a quick turn into wind and drop and return to previous course . Clearly not an idea for a narrow channel but it’s possible there as well . Whether you can reel in an inmast quickly tended not to be my impression from med charters but as said they are less demanding certainly. As for reefing on a Bav34 you can free off the traveller and to honest if going upwind for any distance unless in wide open spaces you are probably best to reef around 15kn to maintain control as they head up otherwise unless your crew is attentive particularly if your headsail is the standard full cut version. What you tend to do is get that headsail down to a better size fairly quickly anyway. I cannot really speak as to speed but in light airs they will outsail an equivalent Hallberg of similar era . Once it gets to say 20kn the Hallberg will be happy though whereas the Bav needs the reefing in well before
