Travellingwithtoby
That had me in fits of laughter ???There's an oft quoted saying something along the lines of - if it flies, floats or fornicates, rent it...
Yes I think this will come later on on life, I have a broad engineering background and had already considered a steel hull, but the only one I could find had been boarded tightly inside making me feel uneasy about being able to check for corrosion without a major refit.Sounds like you need more of a seagoing workshop minimizing sleeping space to one bunk settee with galley and wctherestfitted as work space maybe with large access to lower in an engine to work on.Youneed a steel 11 meter old motor sailer that you can fettle to your requirements .Preferably shallow draught
Access to sheltered creeks or drying harbours and normally these places provide shelter from bad weather and access to shops and cheaper mooringsYes I think this will come later on on life, I have a broad engineering background and had already considered a steel hull, but the only one I could find had been boarded tightly inside making me feel uneasy about being able to check for corrosion without a major refit.
Most of what I will be doing will be onboard the other persons boat, unless it's something that requires silence and expensive kit (injector rebuilds) common problems I would hope will be easily repaired without removal of the engine!
Now you have peaked my interest, why the shallow draft?
How about a centre cockpit boat like a Moody 33 - turn the aft cabin into your workshop? There are some old centre cockpit aft cabin boats where it might work if you gut the aft cabin, Moody 33 asking prices though haven't come down like some others. One or two of the Macwesters have aft cabins and are solid, cheap, boats. If aft cabin not really big enough for a small workshop could certainly be a tool store. I wouldn't buy an old steel boat, too much work...
I will have a look, I think the reason i went off the macwesters was fin keel, i would not feel safe on anything without a full keel personal opinion, old seaworth boats had them so it makes me feel safe.How about a centre cockpit boat like a Moody 33 - turn the aft cabin into your workshop? There are some old centre cockpit aft cabin boats where it might work if you gut the aft cabin, Moody 33 asking prices though haven't come down like some others. One or two of the Macwesters have aft cabins and are solid, cheap, boats. If aft cabin not really big enough for a small workshop could certainly be a tool store. I wouldn't buy an old steel boat, too much work...
Haha the most single minded person he had ever met, I'm not sure if I should be worried but I feel like that describes me in a sense!True, Toby, that Webb Chiles' site is a lot to digest at first sight.
Clicking 'articles', there are four that might be of particular interest:
1, How to Escape
2. Call of the sea
3. Why I sail, and,.....
4. The Seasick Kinjaku and other stories.
Story number three is about an Englishman named Spencer who is none other than the UK's very own Les Powles, a totally committed, obstinate and persistent chap if there ever was one, who called Webb in his own biography, "the most single minded person he had ever met" after meeting up with him while cruising the Southern Hemisphere.
No connection (other than I have the 31' version) this looks like a lot of boat for the money:
Contest 33 for sale UK, Contest boats for sale, Contest used boat sales, Contest Sailing Yachts For Sale 1971 Contest 33 - Apollo Duck
I like the idea of the aft cabins, does this effect anything else on the boat? Handling etc?
Old steel boat. There is one for sale, I can work with steel why do you feel they are more work than say a grp boat?
I'm gutted I had my eye on a boat and its now under offer
Yes it does look good, there are a lot of boats out there and it's quite overwhelming!No connection (other than I have the 31' version) this looks like a lot of boat for the money:
Thank you for clearing a few points up for me!Earlier fibreglass boats simply copied old designs but when they realised that with FG you could have smaller, different shaped keels either made from steel & bolted on or moulded as part of the hull and then filled with ballast they started experimenting with different designs, bilge/twin keels, e.g. Having said that I do like a full or fullish keel with encapsulated ballast myself - for ease of maintenance and directional stability, but those older plastic boats are built strongly and have crossed oceans, to discount them all en masse just because they're not full keel would be to unnecessarily restrict your choice of boat (in my humble opinion of course). It is a real buyers market at the moment, there's no need to rush in to anything & there's plenty for sale...
Being able to do repairs etc. on a steel boat is all very well but if it needs lifting to do it that costs. Older steel boats need much more time & attention to integrity and finish than plastic, as do wooden boats. Here's a curveball - ferrocement hulls on the other hand can be relatively maintenence free if you can find a good one (I repeat if you can find a good one). You can leave a good ferro boat in the water for years and they're cheap cos nobody wants them. I had one that I kept in Greece for a few years...
Almost every boat out there now is fin keel bolted on, so inevitably they are the ones who get reported when very occasionally structurally damaged.Thank you for clearing a few points up for me!
I am still unsure of if I would trust a fin keel boat, especially as I am still learning to a point and need to get back on the sea again after over 12 years of land... is a full keel going to make such a difference when anchored in chop and also against grounding damage ?
I hope I never have to find out! But I'd rather have the safer option if I get the choice!
Yea I think steel and ferro cement are beyond my scope for now.
Most cruisers like me over 40 years have had multiple fin keel boats in lots of different locations and sailing conditions and a few accidental groundings with no problems associated with the keel or hull.
Get the boat that suits what you need to live on and fits with your ideal of sailing - Scott of the Antarctic, pipe smoking fettler discussing stanchion posts sheltering from the drizzle in a warm pub, sea gypsy in the Caribbean or just a floating caravanner taking the dinghy ashore to a Sicilian bar for breakfast after a stormy night sail.
Buy the the boat that fits your particular dream and don’t worry about the keel configuration.
Thank you for this,Almost every boat out there now is fin keel bolted on, so inevitably they are the ones who get reported when very occasionally structurally damaged.
That is very useful information! Thank you very muchIf you are going to manoeuvre in crowded waters (marinas), when initially going astern, fin keeled boats a far easier to handle. If there is any significance crosswind a long keeler can become near impossible.
Bow thruster clipped the rudder?That is very useful information! Thank you very much
So the answer is if there is no wind then park astern using prop walk to decide what side of the berth I moor in and if its blooody windy.... just moor hahaha
Would something like a bow thrusters be of use? I saw one the looks as if it clips to the rudder? Only asking out of curiosity
