Very sad. Prickly has little protection to the south.We have friends out there. One in Prickly Bay, Grenada, was lost on the rocks and another was on the hard in Carriacou that has been severely damaged. Not good at all!
This is the beach in Prickly Bay...
Friend of a friend slept onboard his boat just along the coast from Prickly Bay. Max wind where he was, was 37 knots. He slept through everything.Very sad. Prickly has little protection to the south.
The bays to the east of Prickly have reefs to shelter them. Much better place to be.Friend of a friend slept onboard his boat just along the coast from Prickly Bay. Max wind where he was, was 37 knots. He slept through everything.
Agreed. I hope people won’t mind if I’m not explicit about where they were. My friend moors his boat there and I suspect the biggest danger is other boats pitching up and anchoring but then dragging down into him!The bays to the east of Prickly have reefs to shelter them. Much better place to be.
Sorry to see the crack. The good news is that GRP repairs are easier to DIY than extruding a new mast, so hopefully you will be able find a repair solution - even if inelegant patch but enough to get the boat to somewhere can do a full repair.Hard to gauge the size of the crack from this, but you get the idea. It's not great. We're really not going to know until the boat is upright again.
Agreed. It will all depend on what might have been damaged internally. Hopefully lots of grinding, woven matting and epoxy will regain the hull’s integrity & strength. Hopefully no great damage internally. Getting it to look cosmetically perfect is a more of a challenge but easy enough for a professional GRP repairer and can wait if necessary.Sorry to see the crack. The good news is that GRP repairs are easier to DIY than extruding a new mast, so hopefully you will be able find a repair solution - even if inelegant patch but enough to get the boat to somewhere can do a full repair.
Agreed - obviously you need to be sure of a structurally sound repair, but often in these cases the the bulk of the time/cost can be in the fairing and final finishing . You may be able to get cruising again on a boat that's seaworthy (if a little rough cosmetically) without spending a fortuneAgreed. It will all depend on what might have been damaged internally. Hopefully lots of grinding, woven matting and epoxy will regain the hull’s integrity & strength. Hopefully no great damage internally. Getting it to look cosmetically perfect is a more of a challenge but easy enough for a professional GRP repairer and can wait if necessary.
A poured concrete house with flat concrete roof and steel storm shutters is the way to go. It can look like any other house if you add a pitched roof. The problem on these small islands is there is no cement works. You can't order a concrete wagon full. Everything has to be mixed with a cement mixer. The houses there are timber traditionally, and more recently breeze block with minimal rebar reinforcement. Roofs are sheet metal and often just nailed on.It’s heartbreaking viewing that. What sort of percentage of Cariacou home owners are insured against hurricane damage?
Ever since this thread started I’ve been thinking about what a hurricane resistant house would look like. If houses resembled upside down bowls would that work? Just thinking aloud really.
You have hit the nail on the headA poured concrete house with flat concrete roof and steel storm shutters is the way to go. It can look like any other house if you add a pitched roof. The problem on these small islands is there is no cement works. You can't order a concrete wagon full. Everything has to be mixed with a cement mixer. The houses there are timber traditionally, and more recently breeze block with minimal rebar reinforcement. Roofs are sheet metal and often just nailed on.
They don't have a hurricane code to build to and if they did, the locals could not be able to afford it. They don't even seem to have hurricane shelters built to a hurricane code.
You are on the wrong island and country. We are talking Carriacou. Its part of Grenada. Curacao is about 500 miles westThere is no reason why a concrete plant and building codes can't be in place in this day and age. Bulk cement powder is made remotely and transported globally to various intermediaries before onward transfer to where it gets mixed into concrete and local building sites. I lug around 414m3 of bulk cement powder and get refills globally on my drill ship in out the way locations, more backward than the likes of Curaçao, land rigs globally have bulk cement powder moved across deserts and arctic wildernesses, a very large housing estate just completed where I live had bulk cement delivered to a portable mixing plant, on location for about 3 years. It is also very low cost because it is made in large quantities and steady demand, so very competitive. Mixing cement into concrete or just cement slurry, to a quality standard or specification is not difficult or expensive. Rebar is 10 a penny. If there was a will, it could be done at an affordable price point for the country. Of course the market on an island like Curaçao is small, private market does not have to be the economic model that is applied.
Reality on the ground is that the residents need shelter now, so they will rebuild cheap and fast.There is no reason why a concrete plant and building codes can't be in place in this day and age. Bulk cement powder is made remotely and transported globally to various intermediaries before onward transfer to where it gets mixed into concrete and local building sites. I lug around 414m3 of bulk cement powder and get refills globally on my drill ship in out the way locations, more backward than the likes of Curaçao, land rigs globally have bulk cement powder moved across deserts and arctic wildernesses, a very large housing estate just completed where I live had bulk cement delivered to a portable mixing plant, on location for about 3 years. It is also very low cost because it is made in large quantities and steady demand, so very competitive. Mixing cement into concrete or just cement slurry, to a quality standard or specification is not difficult or expensive. Rebar is 10 a penny. If there was a will, it could be done at an affordable price point for the country. Of course the market on an island like Curaçao is small, private market does not have to be the economic model that is applied.
