Fin keels - Moulded or attached fin?
doug748
1 Oct 2002
UK. South West.
An interesting question has been raised on the thread: If you were buying a cruiser...
.Rather than divert that thread, here is a new one, the question was:
Are bolt on fin keels a forward or backward step for small yachts?
I know where I stand on this. What does the panel think?
Kelpie
15 May 2005
Afloat
It depends. I think that beyond a certain aspect ratio it no longer makes sense to encapsulate, in fact it would be stronger to bolt on. Lower aspect ratios can be encapsulated though.
Eyore
19 Oct 2013
West coast Ireland
Correct , but if a particular boat ticked all my boxes and the price was right the method of the keels attachment would be utterly irrelevant.
doug748
1 Oct 2002
UK. South West.
Yep, if you want a narrow fin and extreme draught (and all racing boats do) then you have no choice.
However for a cruising design, and in terms of engineering, the bolt on keel has little to commend it in my view.
sailorman
21 May 2003
Here or thertemp ashore
moulded in has water ingress issues if the grp is damaged & the ballast isnt real lead
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
I can't say I've ever studied yacht building, but I assumed that encapsulated keels were bolted on anyway, not merely supported by a skin of GRP. If that's true, the difference with encapsulation is that it is not possible to remove the keel to check on the status of the bolts...
Mike.
flaming
24 Mar 2004
Only if you accept that cruising means slow.
There are plenty of people who like to cruise in fast boats, and an encapsulated keel (for all their undoubted good points) is slow.
sailorman
21 May 2003
Mike.
encapsulated = no fixings its fully encapsulated all round
sailorman
21 May 2003
Screw on keel, he fall off instead.
Not with the amount of s/s bolts mine has
Blueboatman
10 Jul 2005
Bolted on keels will take a lot of bump-oops-a-daisy abuse..But I do like the hollow, deep, spare space that is associated with encapsulated keel profiles, both single and twin, in mine own ownership..
A good long cast iron keel has, arguably, saved many a wooden boat from old age droopiness ( cos it don't bend like wet wood, innit)
Neil_Y
28 Oct 2004
Devon
www.h4marine.com
Neither, just an alternative in a wide range of older cruising yacht designs, the most recent cruising yacht keels being of a pivoting design like this...
Some of the best cruising designs have benefited from the developments in racing, but that's just my idea of a nice cruising design.
