Tranona
I thought s/s keel bolts were frowned upon because of the possibility of crevice corrosion leading to sudden failure.
Not in modern construction where the bolts, or more usually studs do not get wet.
Only if you accept that cruising means slow.
There are plenty of people who like to cruise in fast boats, and an encapsulated keel (for all their undoubted good points) is slow.
Given two identical fin designs, I guess the hydrodynamic performance would be the same.
The encapsulated design would perform better on the water because it's Centre of Gravity is in the right shop. Too much of the cast keel is there simply to support the bottom third. The effect is made worse by all the frameworks and steel in the bottom of the boat designed to cope with point loadings and stop the thing falling off.
Given two identical moderate cruising fin designs, I guess the hydrodynamic performance would be the same.
"Moderate cruising fin designs with steel frame works? That's certainly not very usual." Tim Bennett
It is quite common though I agree not usual. That is why I was careful not to say it was.
OK you say quite common. What percentage of moderate cruising fin designs are adulterated by steel frame works?
I wouldn't call X-Yachts moderate cruising fins and the other makes are ?
Real boats dont have that steel grid. its all done to save weight & moneyA number of boats boast steel reinforcement in the hull. The rest all have studs and/or washers, spacers, backing pads and nuts to hold the thing together. What I said was:
"The effect is made worse by all the frameworks and steel in the bottom of the boat designed to cope with point loadings and stop the thing falling off. "
I do look forward to the day when hydraulic-powered canting keels are to be found amongst regular cruising yachts. That would give you guys something to disagree over!
encapsulated = no fixings its fully encapsulated all round
There is. Tungsten is 50% heavier than lead. It used for balance weights on F1 cars.
