Filling small holes in deck?
bumblefish
22 Dec 2002
Brighton
I have removed a couple of redundant deck fittings, I was planning on filling the holes, after cutting a small flange, with epoxy. Would it make any difference if I used a small amount of low density filler or similar?
michael_w
8 Oct 2005
I'd always add coloidall sillica to any epoxy used for filling/fairing. According to my very knowledgable chum (ex Green Marine, Fairline, Halmatic et al) The sillica stabilises the resin/catalyst mix otherwise the catalyst tends to penetrate the laminate leaving the resin behind.
It is also a darn sight easier to handle as "mayonaisse" than "golden syrup". For a basic fill and fair job I suggest a mixture of sillica and low density filler.
boatmike
30 Jun 2002
Solent
In fact solid epoxy tends to crack. Usual boatbuilders dodge is plug hole with Sikaflex up to about 3 mm then finish with gel coat. Being flexible it never leaks and it's only drawback is that it discolours under UV light. A good chamfer on the hole will be OK for bonding gel coat and if you use a fine plastic scraper to wipe over the top you should not even have to do more than polish it
alan006
7 Jun 2007
Kent
Microporus ballons are very good for adding to epoxy where you want to sand it back. Coloidall sillica is used to thicken and increase the adhesive qualites of epoxy. Microporus ballon filled epoxy is strong but easier to sand than epoxy with colloidall silica.
