Bobobolinsky
Since you have a saturated gas/liquid mix in the tank, pressure is dependent on temperature and nothing else. As long as there is a some gas there when you fill, and you don't pump it, I can't see how overpressuring could arise. When I fill my car with LPG it is pumped, so the fuel in the tank warms slightly and the consequent pressure increase shuts off the pump at about 85% full: less if filling from near empty, more if it was almost full when I started.
Good idea, but as long as you don't let it squirt on flesh - or smoke - a tube full of liquid propane isn't a particular problem.
Nope, the tank in your vehicle has a level guage, which cuts off the flow at 85%
Overfilling a cylinder, will hydraulically pressure the tank. This is unlikely to rupture the tank as the pressure relief valve will lift, but the noise as it lifts is a little scary and don't have any naked flames around when it does.
