GHA
Think they got confused by the navy's sloppy use of lat/long format
in industrial environment " a collision that didnt happen " is classed as a " near miss " , the case is studied and hopefully lessons are learned and acted upon , not dismissed because there is no excuse available .Hiya, I'm not going to get drawn into an argument here with the rights and wrongs of the risk of collision that didn't happen! But I'm fairly sure that twenty months ago there were some very uncomfortable moments in a senior officers office ashore back at CSB and the miscreants got the bollocking they deserved for stupid. The emergency go deep procedure is regularly excercised. No idea why they didn't, even after reading the report.
Not sure what you mean by a one compartment standard. The pressure hull is divided into watertight compartments. The forward one, whose watertight door is permanently manned, could be flooded, probably, without loss of the boat. Mebbe. Problem is the ballast tanks outside the pressure hull. Once badly damaged, you are cream crackered.
All I can add is that from what I saw sat in the Ship Control seat for gawd knows how long dived, is that such mistakes are rare and the standard of professionalism through the the control room and sound room is very high. Others may read newspapers and think otherwise.
Did you read the MAIB report? ? I can't see where it says oopsadaisey.in industrial environment " a collision that didnt happen " is classed as a " near miss " , the case is studied and hopefully lessons are learned and acted upon , not dismissed because there is no excuse available .
Well actually I was told to dread naught so I valiantly went tirelessly forward and became superb.A very astute post, if I may say so. Were you in the vanguard of sub drivers?
Why not? At the end of the day it’s a piece of government IT...
It‘s only as good as the data fed into it, and according to the report the only range input was the periscope watchkeeper’s guess. Radar not being used, passive sonar only gave a bearing, and AIS only received very intermittently (although it’s not clear why that should be, even from a low-lying antenna, when the ferry was so close).
So the OOW "had the ship (boat)". The Navigator was supervising, and was periscope watchkeeper. In what way did the Navigator then "take over the periscope watch"? I thought he was already doing it.1.4.1
The submarine’s OOW was a qualified submarine officer and this was his first period at sea in the OOW role. The periscope watchkeeper was the navigating officer who was a qualified and experienced submarine watchkeeper. Although initially supervising a trainee, the navigating officer took over the periscope watch when the ferry was reportedly at about 6000yds.
It seems submariners still use yards.Think they got confused by the navy's sloppy use of lat/long format
"Yards" most are tied up in them as floating "spares" departmentsIt seems submariners still use yards.
I wonder if they still use fathoms and ride about on penny-farthings.
Bit boaty innit?
Almost a colregs thread
I honestly couldn't even hazard a guess why not but would have thought that a tactical system would be a little more robust than manually inputing someones guess.
I'm surpised Nicola Sturgeon and her one party state SNP Government hasn't been blamed yet.
I knew having a bolted-on keel had some advantage... ;-)The Americans on the Clyde used to be even worse. I had one of the bastards approach on the surface at some speed, dive under me and resurface on the other side. I gave the keel bolts some welly with a hammer and hope it hurt someone.
For which of the three Naval Officers do you think it was 'Bad for Career'?Just a thought, but in the RN, this is probably a 'Bad for career' event.
Had it been a govt event, the man responsible (it's got to be Grayling) would've been lauded for his adventurous attitude in determinedly testing maritime watchkeeping skills.
Bloody lucky that the Falklands happened 38 years ago...I believe that’s in the “attack periscope”. At least, in the days of optical perisopes, it was. All digital, now.
In what way?Bloody lucky that the Falklands happened 38 years ago...
