Used scaffold boards for years .To rope up drill a couple of biggish holes , one either end of the plank then from the top edge down drill into the big hole then rope ?After an interesting night alongside at Stonehaven I think it is about time I invest in a fender board. Is a discarded scaffold plank the best way forward or something a bit less 'agricultural'?
Sometimes you need a board to go alongside a pile, allowing for some tide movement.I made 2 short ones out of a scaffold plank, easier to stow in a locker, and more versatile to use.
each fender board was not much longer than 2x diameter of sausage fender.
... wonder if there is an optimum size?
A foot longer is good when you're using it......., wonder if there is an optimum size?
Yes, unless planning to use as a gangplank, I think a scaffolding plank is needlessly wide and heavy. Using a piece of wood of an appropriate size can be much lighter and easier to store. This is what we did similarly only 4-6 inches wide but ours is perhaps 6-7 foot long.We carry two on board as piles can be some distance apart, cheap 4" x 2" scant x about 4ft long, . Double up on ladder as passerelle.
