steve yates
My tiller pilot, simrap tp-10, was playing up, intermittently at first, coming back with a wiggle of the wire, then giving up entirely. when I opened up the plug the blue cable was had pulled out from its connecting pin. While taking it apart I forgot which cable had gone to which pin (duh)
I have reconnected them both ways around, but on plugging into the socket aboard there is nothing from it whatsoever.
What tests should i run with my multimeter (total novice with one) to check whats what with the plug/cable on the tp and the socket on the boat?
Also, how do I know which pin to wire the pos and neg to? I have kind of assumed that with the fat pin up (unused) the blue goes to bottom left and the brown to bottom right pin, is there a way to use the multimeter to check the polarity of the matching socket holes to check this?
