AntarcticPilot
I have a Moody 31, and most of the headlining is on thin plywood panels that are screwed to a framework of battens that are glued to the fibreglass. As a lot of wiring runs behind these panels for lighting, instruments and navigation lights, it would be helpful to replace the woodscrews with something a bit easier to do and undo, without the potential to end up with holes in the battens that have become worn and enlarged. I will be replacing the headlining material as well.
I am looking at T-nuts such as these or insert nuts such as these. WHich would be better, or is there a better option? Although Stainless steel is probably not absolutely necessary, I suspect it'll avoid rust marking in future. I would probably use simple dome-headed stainless bolts of appropriate size, perhaps with Allen heads rather than slotted heads.
Does this sound like a reasonable plan? Any suggestions? At present getting the headlining down is not particularly difficult, but putting it back up can be a bit of a pain, especially trying to align the screw holes! It's not exactly an everyday activity, but access to the fittings for masthead fittings especially is something that is needed from time to time.
