Essential tools
I wouldn't bother with WD40. ACF50 is far superior, and leaves a corrosion-resistant and lubricating film behind.
I'm curious - what's the 24mm socket for? All I can think of is the prop nut and, If I need to get involved with that, I'd say my delivery trip is over.
When sailing on other people's boats, I always carried a good multi-tool, plus another cheapo that had a small crescent wrench. I earned a good few brownie points with them fixing stuff.
The 24mm nut removes both the steering wheel on our boat and the sail-drive prop nut. I was eluding to not needing a further 1/2 drive socket set if you get a 3/8 24 mm which sadly isn't in 3/8 drive sets, so you've got everything you need on the boat.
But I take your point about the prop nut on a delivery!
Thank you for this list and I want to ask you explicitly to post this Rigging and Sailmaker list.
For me it is amazing how many tools one can carry and then you see somebody elses toolbox or -list and there is something you do not have yet.
I am not saying that one must have these items on the boat - obviously dependent on the boat - but the idea is what couts.
So if youreally do not want to trigger some minimalistic comments: please send it to me as private message.
Thanks.
Here uou are:
Rigging & Sail Repair
Tools
30m Tape rule
Bolt croppers
Deck pliers
Fid
Hog ring pliers
Knife
Palm
Pop rivet gun
Rig tension gauge
Rope cutting/sealing gun
Sail hook
Sail needles for Speedy Stitcher
Sail needles, ordinary
Seam ripper
Selma splicing fids
Shackle key
Shackles, D
Shackles, bow
Shackles, snap
Shackles, twisted
Speedy Stitcher
Thread snips
Wire twisting pliers
Consumables
ACF-50 spray
Beeswax
Blocks, assorted
Canvas off-cuts
Chalk
Duralac paste
Eyelet kit
Felt marker pen
Hog rings
Pop rivets, assorted
Rings for tie-downs
Sail cloth offcuts
Sail repair tape
Sail threads
Shock cord
Self-amalgamating tape
Seizing wire
Soapstone pencil
Split pins
Track slides
Webbing
Whipping twines
Winch grease
Here uou are:
Tools
30m Tape rule
Bolt croppers
Deck pliers
Fid
Hog ring pliers
Knife
Palm
Pop rivet gun
Sail hook
Seam ripper
Selma splicing fids
Shackle key
Shackles, D
Shackles, bow
Shackles, snap
Shackles, twisted
Speedy Stitcher
Thread snips
Consumables
ACF-50 spray
Beeswax
Blocks, assorted
Canvas off-cuts
Chalk
Duralac paste
Eyelet kit
Felt marker pen
Hog rings
Rings for tie-downs
Sail cloth offcuts
Sail repair tape
Sail threads
Shock cord
Seizing wire
Soapstone pencil
Split pins
Track slides
Webbing
Whipping twines
Winch grease
Goddamn. Needs a whjole frigging garage full of tools for the "essentials".
Honestly I think it's a bit over the top. This is probably all you want on your boat, but that isn't the barebones of a necessary minimum
It doesn't matter very much to me what you think. I was answering the OP, not you.
But if you look at my first post in this thread (#21) you will see that I wrote :
" I should point out that, latterly, I kept my boat in France (300 miles from home) and it would have been galling to have had to buy something in France that I already had at home."
Here uou are:
Tools
30m Tape rule
Bolt croppers
Deck pliers
Fid
Hog ring pliers
Knife
Palm
Pop rivet gun
Sail hook
Seam ripper
Selma splicing fids
Shackle key
Shackles, D
Shackles, bow
Shackles, snap
Shackles, twisted
Speedy Stitcher
Thread snips
Consumables
ACF-50 spray
Beeswax
Blocks, assorted
Canvas off-cuts
Chalk
Duralac paste
Eyelet kit
Felt marker pen
Hog rings
Rings for tie-downs
Sail cloth offcuts
Sail repair tape
Sail threads
Shock cord
Seizing wire
Soapstone pencil
Split pins
Track slides
Webbing
Whipping twines
Winch grease
Thank you so much!
Most of the things I already have (some words I will have to look up in the technical dictionary) but is is really interesting what other people come up with after years of expperience. I thank you honestly.
Of course spares and such are actually on board your boat or your safari vehicle or similar to prevent the relevant part to fail. One carries them to help other guys who then really admire your planning ... . But sometimes these inexplicable spiritual forces do not work and then, then you have the right tools, parts, material to fix the whatnot that broke.
This all depends a bit on how isolated the places you aregoing. A classical marina-hopper will probably just have to take a fat cheque-book.
cheers, g.
I'm curious - what's the 24mm socket for? All I can think of is the prop nut and, If I need to get involved with that, I'd say my delivery trip is over....
The kit is for a one-off delivery voyage. I wouldn't argue about the merits of various fluids, they'll all do the same job. FWIW I'd take oil e.g. 3 in 1 in a spray can.
24mm is a standard size and not uncommon, but above 19mm I'd rely on a 10" (sorry, 250mm!) adjustable.
Two rolls of gaffer tape ( I'd never find the first one ) and a bigger hammer.
Oh, and kidding apart - an adjustable that could be used to disconnect a gas regulator that was so corroded and leaky that I removed it completely and chucked it overboard.
