Essential tools
Here's my list for engine and boat maintenance. I had another list for sail and rigging. I should point out that, latterly, I kept my boat in France (300 miles from home) and it would have been galling to have had to buy something in France that I already had at home. Also the boat was old and had a lot of woodwork in her construction.
Tools
Allen keys
Bench hook
Box spanners
Brass drifts
Breaker bar ½” (for sockets)
Broken screw extractor
BUKH special tools
Carpenters rule, boxwood
Centre punch
Chain wrench
Chisels
Clamps, edging
Clamps, ordinary
Cold chisel
Crimping tool, small
Crowsfoot wrenches, 13,17, 24mm
Dental mirror
Die nuts
Drill, re-chargeable, Makita
Drill bits
Easy Outs
Expanding rule, 30m, Stanley
Expanding rule, small
Feeler gauges
Fein Multimaster + accessories
Files, various
Flush cut saw ‘Veritas’
Hacksaw, junior
Hacksaw, large
Hammer
Hand brace
Inspection lamp
Mallet, carpenter’s
Mallet, copper
Mole grips
Multimeter
Nail punch
Pad saw
Pin punches
Planes
Pliers, circlip
Pliers, large
Pliers, snipe nose
Propeller extractor kit
Rasp, farmer’s
Scrapers
Screwdrivers, cranked
Screwdrivers, Philips
Screwdrivers, pozidrive
Screwdrivers, slotted
Sealant gun
Sharpening stone
Side cutters
Sockets, ½”, assorted
Socket set, ¼”, Stanley
Sockets, large, for injector
Soldering iron, 12v
Spanners, adjustable
Spanners, normal
Stanley knife
Stillson wrench, long
Stillson wrench, medium
Strap wrench, ‘Boa Constrictor’
Tap & die set
Torque wrenches x3
Vernier calliper
Vice, clamp-on
Wheel brace
Wire strippers, various
Wood saw
Zyliss vice
Consumables
Alox papers, pads, discs
Anti- galling fluid (for s/s)
Captain Tolley’s Creeping Crack Cure
Contact cleaner spray WD40
Crimps for wiring
Emery paper
Epoxy kit
Filler, gelcoat
Filler, general purpose
Filler applicators
Gasket cement
Glycerine [for Johnson pump]
Gorilla 5-minute epoxy
Gorilla polyurethane glue
Grease, Copaslip
Grease, general purpose
Grease, high pressure for Rotostay
Grease, seacock
Hacksaw, junior, blades for
Hacksaw, large, blades for
Hammerite primer paint
Hammerite red gloss paint
Hammerite thinners
JB Weld (epoxy)
Latex gloves
Liqui Moly Engine Preserver Spray
Minigrip bags
Oil, e.g. 3-in-1
Plastic wood, eg Brummer
Plus-gas penetrating oil
Sealant, eg CT1
Solder
Thread sealant, Loctite 572
WD40
I had a fairly extensive tool kit on my boats but no mallets, adjustable spanners or crowbars. They were mainly used during the winter spring lay-up and fit out rather than on voyages although they did find use on more than one occasion on others boats.
Photodog late of this parish used to marvel at the never ending streams of various tools and expletives that accompanied their use when I was working on some aspect of boat maintenance.
When I bought the Albin Vega over the course of a few weeks I found all the tools I needed on the boat ,even a hammerwithfourinch shaft……all abit rusty but all fitting important nutsetc
Tools
Allen keys
Bench hook
Box spanners
Brass drifts
BUKH special tools
Centre punch
Chain wrench
Chisels
Clamps, edging
Clamps, ordinary
Cold chisel
Dental mirror
Die nuts
Drill bits
Easy Outs
Feeler gauges
Files, various
Hacksaw, junior
Hacksaw, large
Hammer
Hand brace
Inspection lamp
Mallet, carpenter’s
Mallet, copper
Mole grips
Multimeter
Nail punch
Pad saw
Pin punches
Planes
Pliers, circlip
Pliers, large
Pliers, snipe nose
Rasp, farmer’s
Scrapers
Sealant gun
Sharpening stone
Side cutters
Soldering iron, 12v
Spanners, normal
Stanley knife
Tap & die set
Torque wrenches x3
Vernier calliper
Vice, clamp-on
Wheel brace
Wood saw
Zyliss vice
Consumables
Crimps for wiring
Emery paper
Epoxy kit
Filler, gelcoat
Filler applicators
Gasket cement
Grease, Copaslip
Grease, seacock
Hammerite thinners
JB Weld (epoxy)
Latex gloves
Minigrip bags
Oil, e.g. 3-in-1
Sealant, eg CT1
Solder
WD40
I’ve changed my mind, Snap-On roll cab and top box as the bare minimum!
Yeah, have done that just now hahahaha *cries*.
Went to the boat, time pressure from hell and we had to rush everything, I hadn't even had a chance to test the engine beforehand. I had it on good account from both the previous owner and the boatyard themselves from months ago, plus a survey, that it SHOULD start, but you know how those things are.
Well, I arrive and all 3 batteries are fubar. Something was left running and drained them to death.
Had to buy a new battery to at least be able to start it. (which it then did right away once I hit the water) but that's when I realised, there isn't even a single spanner on the boat.
So I had to get a basic tool kit, like the absolute basics. Hammer, few screw drivers, clamps, spanner that sort of thing.
I also bought a saw to cut things if needed. Some underwater epoxy, a handpump (in case none of the boat ones work, that way I can at least pump by hand). Bit of spare wiring and a set of bolts.
I brought my own flotation device, headtorch and my very own handheld vhf.
So, from this experience this is the absolute minimum I'd bring.
I wouldn't bother with WD40. ACF50 is far superior, and leaves a corrosion-resistant and lubricating film behind.
3/8 drive set and also a 24mm if its not included
I'm curious - what's the 24mm socket for? All I can think of is the prop nut and, If I need to get involved with that, I'd say my delivery trip is over.
When sailing on other people's boats, I always carried a good multi-tool, plus another cheapo that had a small crescent wrench. I earned a good few brownie points with them fixing stuff.
I had a 24mm socket on board.
I can't now recall what it was for but I wouldn't have bought it if I hadn't needed it (do I hear a derisive snort from The Old Guvnor?).
Perhaps it fitted the cylinder head nuts or the injector.
I know, it looks over-the-top but I don't think there's anything there I hadn't used at some time.
To save myself from further ridicule, I won't publish the Rigging & Sailmaking Kit List. :D
Thank you for this list and I want to ask you explicitly to post this Rigging and Sailmaker list.
For me it is amazing how many tools one can carry and then you see somebody elses toolbox or -list and there is something you do not have yet.
I am not saying that one must have these items on the boat - obviously dependent on the boat - but the idea is what couts.
So if youreally do not want to trigger some minimalistic comments: please send it to me as private message.
Thanks.
