Bodach na mara
A couple of years ago I renewed the impeller of my water pump using the recommended spares kit from Beta Engines, who operated an effective online shop at the time. The kit comprised an impeller and an O-ring and in fact was part of a large selection of serving spares in a nice useful toolbox. The impeller was fine but the O-ring was a bit too large in diameter. I measured it as about 55mm in internal diameter. The cross section diameter was OK at 2mm. I squeezed the ring into the groove as best I could and it seemed to work satisfactorily for 2 years.
Last autumn I removed the impeller for the winter and last week ordered and fitted a new kit, not from Beta as they had changed their site and I found it unusable. Once again the ring supplied is over-sized. This time I cut a small (12.5mm) section out using a craft knife and joined the cut ends using super glue. l made the cuts at an angle of course.
Has anyone else found this problem? I have measured the groove and found the inner diameter to be 52 mm and width 2mm so in future I intend to obtain this size of ring from a bearing supplies dealer.
