Stemar
A friend has a little 24ft motor sailor with a Yanmar engine which starts and runs fine in neutral and astern, but stalls when put into ahead. He's had the gearbox refurbed by the local Yanmar guy, to no avail. The gearbox turns fine by hand, in gear with no noticeable difference between ahead and astern, likewise the shaft and prop. Yanmar guy has been back and checked things over, but the best he can come up with is to increase the idle from around 750 rpm to 1200, which helps, but it still stalls quite often.
Any ideas?
Any ideas?
