prv
I agree. If it comes down to trying to decide whether to take the 15mm or the 17mm then it's not going to end well.![]()
Especially if #9 is right and the nuts are 22mm ?
The advice to leave the feet on the engine instead is good though, as it will probably let the OP slide it forward instead of having to lift straight up and indeed lower accurately back down. Only reason not to is possibly if they’re lag screws into encapsulated bearers and the condition of the material is dubious, in which case leaving that joint well alone might be prudent.
But if he’s leaving the feet on the engine, I can’t imagine how the OP expects anyone to know what size of bolt might have been used on his particular old boat. And, unless he’s taking his tools on his racing pushbike and wants to minimise weight, why he needs to know in advance anyway. Just take the socket-set down, a roll of spanners in case access is tricky, and maybe a big AJ just in case, and see what fits.
