Hydrozoan
I was refering to my own practice of scouring the shelves of M Bricolage when in France!
Ah! My apologies!
Read Vics posts and his links. Oils have progressed for modern engines They are now up to CI spec!
But modern oils can damage an older engine that only requires API CD - see Vics website and the paricular Problems that bosun Higgins experience for fuller info.
I prefer to keep it simple: http://i.imgur.com/gpALGIH.gif
I have been trying to understand all that was written in this thread. Unfortunately it seems that my age is preventing me from reaching a clear conclusion.
The engine on my boat is a Volvo MD2b that dates back to 1973. It is certainly not 'high performance' nor would I say that it classifies as 'heavy duty' since it is only pushing a 32 foot sailing boat. My questions are: "What oil should I be looking for to use in this engine? Failing this, what are possible substitutes? What is to be avoided?"
If someone would kindly provide a simple answer that is clear enough for me to understand it would please me no end.
Thank you in anticipation.
Ideally a mineral oil with a API CD spec. Although in the UK this will be hard to find. You can as in previous posts find it in France. Failing that a mineral oil with a spec of API CF should be easy to find. Avoid synthetic or semi synthetic whatever the man in the shop says.
Vyv Cox has explained why oils with a higher/ more recent API service classification may be unsuitable for older yacht engines but what is the objection to synthetic or semi-synthetic oils ?
So after reading all this, i'm assuming this stuff isn't doing my engine any good? (Thornycroft T95)
It meets API CF spec.
Provided its the correct viscosity there is nothing to suggest its doing any harm! Its even a mineral oil if that is relevant!
I'm certainly not recommending that anyone does what I do ..... but I've always taken a rather cavalier attitude to manufacturers recommendations for oil changes for engines, gearboxes and diffs and have preferred to look at oil discolouration, smell the oil for burned carbon and feel between my fingers to see whether its viscosity and smoothness seems right before deciding whether it is time for an oil change.
I first used fully synthetic oil back in the 70s when it became available although in those days it would have been something like £100 a gallon based on current prices. The first time I stripped an engine which had been run on fully synthetic oil I was amazed how little discoloration on the metallic surfaces had occured. Since then I have only ever used fully synthetic oil in cars, motorbikes and even lawnmowers. The longest I can remember extending the maufacturers oil change recommendation was by a factor of almost 3x before I decided that the oil was approaching the end of its useful life.
My boat engines are Yanmar YMs so a reasonably recent design. I am running them on semi-synthetic because I decided that fully synthetic is too low a viscosity and, being in the Med, the engines are never run cold. I can get semi-synthetic at 15w-40 which meets the Yanmar viscosity recommendation. The oil is still in excellent condition after 2 seasons so I have not changed it yet but might do so this year.
As, I say, I don't recommend anyone follows my advice but, after over 45 years of working on engines, the only main/big/small end bearings I have ever had to replace were on engines running on mineral oil.
Richard
Performance standardsA mechanic in the boatyard suggested using this oil http://www.ebay.co.uk/itm/301499343543
So is this ideal for a Thornycroft T95?
