Csail
N/A
Why are boat engines so noisy? Mine is quite new but is well noisy compared to the Audi 2.5 car engine.
because people tend not to test drive boats and certainly dont compare them back to back, so the manufacturers spend the money on fitting boat show bling.
some brand new mobos would be illegal to use without ear defenders if they were a place of work.
easily improved, far easier to do in build though.
If you compare apples to apples...
A boat engine that is found also in genset, tractor, bus, truck or other use will sound about the same. Listen to a Bobcat or something, they aren't quiet either.
In cars a huge effort goes into silencing - as a matter of fact they are built to incorporate sound barriers, vibration stoppers etc.
No so in a boat. The engines sits right on the spine, sometimes on rubbers and in rare designs in insulated compartmens. Noise insulation is the main concern and, luckily, often can be fitted afterwards.
I'd suggest you go for items with a documented effect. If you like, you may also find carpets with sounddeadening properties (layer of lead, I suppose).
Get your point.
Thing is that the same naked engine, before encapsulation etc., will make the same noise regardless of use.
And to stay with the initial subject, the difference experienced between uses is down to the sound insulation surrounding it. Built in, added or retrofitted.
Volvo states that their late technology IPS 600 diesel emits 95 dbA at 1000 rpm and 113 dbA at 3500 rpm.
http://www.volvopentastore.net/files/t_ips600.pdf
Common levels for comparison
• 40 quiet residential area
• 70 freeway traffic
• 85 noisy restaurant
• 90 truck
• 90 shouted conversation
• 95-110 motorcycle
Source: http://www.lowermanhattan.info/extras/pdf/062007_SpecificNoiseLevelsforCommonNoises.pdf
Only shows that sound insulation is important and, when done properly makes a huge difference. It goes without saying an engine which by design makes less noise needs less insulation (like Volvo D4, Yanmar (BMW) 3 litre and more) to reach a comfortable level.
