steve_cronin
N/A
We cruised in company with a boat from Argentina a couple of years ago.
The owners had bought the boat, disused for several years but in "as new" condition, mechanically and internally off of a swinging mooring on the River Plate.
Manolo, being himself a mechanical engineer, was intrigued that the deceased owner/builder had gone to great lengths to duct combustion air into the engine from the outside. Further investigation revealed that this had been done on the recommendation of the local Volvo dealer/mechanic who was very certain that many engine failures in that hot climate were contributed to or even caused by the intake air being far too hot as it was sucked from around a well insulated engine box. In an automotive application, combustion air, once a suitable operating level is attained, is sucked from outside the engine bay where possible and even the engine bay itself is well ventillated in comparison to a yacht's where supressing noise levels seems to take precidence.
Now I have to reveal that MY investigations both here and in Greece show some considerable support for the same idea.
I therefore intend to take the following action:-
I will extend the "below decks" ventillation trunking right up to, but NOT exclusively CONNECTED to the engine air intake. This is one aspect of Manolo's boat I didn't like. His engine air intake pipe is sealed to a duct running up a trunking inside the boxing on one side of the main hatch to a metal grill with protecting louvres. Now I know that this is a well protected position as high up as possible and that the boat is a veteran of a very long ocean passage but if it ever DID get pooped, sea water would go straight into the cylinders of the engine. My intended installation would avoid this by stopping short of the actual air filter intake.
A further adaptation would be to use the second of the vent pipes (both right aft near the gas bottle stowage if you know Bavarias) to supply cool air to the other side of the engine in the vicinity of the alternator to keep that cool when it is running in "boost" via the Sterling controller.
Anyway, probably of no relevance to UK owners, but to those in the tropics and the Med. I hope that this is of interest.
Steve Cronin
Steve Cronin
