homerj
Is there any chemical which will dissolve encrusted salt. I am trying to remove the water feed pipe between the power head and the water pump on my Johnson 8 hp where it passes thru the centre section of the leg. It passes thru a guide hole in the leg about 3/4" diameter and 8" long which is full of salt and is very difficult to shift. I have tried water, vinegar, WD40 and all of the above with a blowlamp and poking with a welding rod with little success. The pipe is copper running thru the alloy leg section... HELP...
