billyfish
Anyone know if the Ultima outboard can be charged onboard ,12volt, any other comments welcome
I couldn't see thatI think they'd mention the availability of a 12v charger on the manufacturer's website if they offered one.
I believe Epropulsion &/or Torqeedo offer one, but they're a bit more expensive.
It’s partly pure marketing fib (as you have done the accurate power units conversion) and partly careful marketing ambiguous wording of “equivalent to” - as often don’t have petrol outboard on full throttle, so the low speed torque of the electric motor will accelerate quickly compared to a petrol outboard on part throttle. And also the torque means can use a different prop.I'd like to know how they all claim equivalent to 3hp yet 1000w works out to 1.34hp by my working out.
Re the horsepower equivalent (specifically that word) statement, I'd prefer it if both manufacturers were clearer than they are. 1kW is indeed 1.3hp. But a 1kW electric motor has much more torque than a 1.3hp petrol motor, so - when fitted with the right sort of propeller - able to provide much more "shove". It won't have the top speed of a 3hp motor - it won't ever get a dinghy on the plane - but when a dinghy is in displacement mode (ie most of the time if you stick to harbour speed limits and/or have two or more people in it) I'd actually say the electric motor is more effective than a 3hp one. And certainly much more pleasant to use. The greater torque is why electric outboards, when designed to take advantage of their different characteristics relative to petrol, tend to turn larger propellers more slowly than petrol "equivalents".
We try to avoid equations because they put a lot of people off reading, but maybe it is unavoidable. …. I agree making spurious claims isn't helpful but I don't think it is unreasonable to suggest that a 1kW electric outboard has quite a similar output to a 3hp petrol one, in terms of what the typical user wants and gets from it. But if you want to get a really lightly loaded dinghy on the plane it is not equal or equivalent. In most scenarios where the 3hp petrol can't plane (ie with more than one person aboard) the electric one will probably be better. Saying it's equal is wrong and if I've ever said that it was by accident of typing or not thinking enough beforehand. "Equivalent" (or even one would hesitate to suggest "roughly equal") is a less definitive term and if you need to get the point across reasonably quickly it is not unreasonable to use it. IMHO
I’d expect them to shout it from the rooftops if it could.I know, all I asked is can it be charged on my boat...before I go and try them
it is simply because it is not the power source that moves the boat, but the propeller. So the meaningful measurement is thrust at the propeller, not potential HP at the flywheel. Electric motors are simply better at delivering usable power to the propeller at displacement speeds. Note how large the diameter of the propeller on an electric outboard is compared with the "equivalent" petrol motor.I'd like to know how they all claim equivalent to 3hp yet 1000w works out to 1.34hp by my working out.
We might not have bothered with a 12v charger, but the option to plug the charger in to a solar panel directly persuaded us.I looked briefly at options for charging on board for most makes the cost of a 12v charger you can get an inverter which whilst less efficient would provide the option for other uses too. It’s worth noting that none of the chargers are that fast, even the “fast chargers”. When you take that into account I started to wonder if a second battery (how much!!!) was a better option.
