Eberspatcher d4 wireing for Sealine
davedpc
21 Nov 2003
reading&upperhamble
Can anyone help me to find how sealine [F33] wire up these units. Im getting power to the thermostat but not to the heater or pump. Need to find an in- line fuse somewhere,if so where is it located?
halcyon
20 Apr 2002
Cornwall
There will be, or was, a panel that had bilge pump float switch fuses, cabin heater , battery charger, and winch circuit breakers, may also have battery isolator switches. You may also find it's pre-wired to where the heater normally fits.
Brian
volvopaul
1 Apr 2007
midlands
hotmail.co.uk
It SHOULD be wired direct to the battery, as it has its own fuse it does not need a separate breaker, to have power to the stat it should have it dthe main loom, brown or red depending how old it is.
