Eberspacher help needed.
Glyn-2008
14 May 2012
Hayling Island
I managed to convince Honey Bunch that a weekend on the boat (admittedly staying on the mooring) may be a pleasant change. We settled down watching the TV with a glass of wine with the heater on. After it had been on for an hour the little 2kw (very old) Eberspacher air heater just turned itself off. I tried to restart it but after 2 minutes it just shuts down again without providing any heat. So a cold night which turned out to be very uncomfortable (high winds, rain etc) has not warmed H.B. to the winter weekends afloat thing. We went home early on Sunday morning, dejected, to find the fence blown down. The best laid plans and all that....
Any help with the Eberheater would be most welcome. Its an old one that does not have the electronic control panel.
Glyn-2008
14 May 2012
Hayling Island
Sounds like the fuel filter to the heater could be blocked, so try removing and cleaning.
Thanks for that.
Presumably its somewhere in the fuel line from the main starboard tank. I am a little worried as I had new fuel tanks fitted and so was not expecting there to be too much "carp" in them to block any filters yet. The fuel pump is clicking as it always did when it was working.
ARA
12 Sep 2011
Serpentine
Your 12v supply is 12v ? The reason I ask is that last year my heating worked & then packed up & stopped working. The reason was that my domestic 12v battery went flat because I had forgotten to charge the battery up
Glyn-2008
14 May 2012
Hayling Island
Hi ARA,
Yes, I should have mentioned that we were on shore Power with our trusty Sterling 30amp charger supplimenting any loss from the batteries. The volt and Amp meters were showing "normal" conditions. I have assumed the glow plug was not to blame as the heater failed whilst in use and not at start up. Also, the amp meter shows a high current drain whilst on the start up cycle now which tempts me to believe that the glow plug is, at least, electrically sound.
Thepipdoc
13 Jun 2009
Torquay, Devon/River Dart
This does indeed sound like a fuel supply issue and the first place I would look would be the filter attached to the Eberspacher fuel pump.
Having said that, I had an issue with my D4 heater and whilst my supply pump would make all the right noises i.e. rapid ticking on start up, and the fuel filter wasn't blocked, it transpired the fuel the pump was delivering was insufficient and a replacement pump was needed.
Once this was fitted it fired up no problem.
My experience of these heaters is there no hard and fast rule in identifying faults and each problem needs to be looked into on an individual basis.
steved
20 Sep 2001
East Coast
It doesnt take much for the filter to have a restricted fuel flow, particularly if it has not been cleaed for a while, this would cause the eber to fire up then die down after a few minutes due to lack of fuel, but you will still hear the clicking.
The filter is quite small and located in a cylinder and presumably not that far from the main fuel tank, there should also be a fuel shut off valve close to the filter.
volvopaul
1 Apr 2007
midlands
hotmail.co.uk
The filter is on the inlet union of the pump, the alloy looking part, unscrew it to find a thimble type filter tucked up inside the inlet union on the pump.
Glyn-2008
14 May 2012
Hayling Island
Thanks Gentlemen,
There is no other filter in the line from the tank and so it must be almalgamated into the fuel pump as you suggest. The heater is a lot older than the fuel tanks and may well have been bunged up years ago as I have never inspected it before.
Would you recommend that I fit an extra in line filter as well as I have just found some available on E-bay for £10 ish. Would be an easy fit too.
fireball
15 Nov 2004
Hope you manage to get the Eber fixed - it could be a number of things including voltage * fuel ...
Anyway - as you've got enough advice on the problems of your heater can I suggest that you 'invest' in a 2kw electric fan heater ... you can use it when on shore power to avoid having freezing nights and they're usually less than £10 !
We have one onboard along with our Eber - the added benefit is that you can use it to boost the initial heating of the cabin when you first arrive.
david_bagshaw
5 Jun 2001
uk
Another thought
Check the fuel can go through the pipe into the burner, as the tip can get fouled in the burner, not letting the fuel into it.
A stiff ish fuse wire is ideal, as it has to go through 2 bends
go for one start to see fuel is delivered to the injection point, if so , do as above.
SC500
10 Feb 2012
Had same problem caused by dirty tiny thimble filter in fuel line at pump union.
I decided to install a new filter as they were only about £4 each, (bought a spare as well as postage was same).
When removing coupling to expose filter there was a slow drip of fuel from the tank side, so you may need a small collector handy whilst changing. The filter sits in a tight recess in the face of the coupling, so you may need something pointed to prise the filter out. Only a 10 minute job. Solved my problem, warm again.
Glyn-2008
14 May 2012
Hayling Island
Thanks to you all for taking the time to provide the excellent information received in this thread. Sadly, I dont have any time for a week to go to the boat and put your fault finding suggestions into practice, but, as soon as I do get to inspect the unit, I will post my findings here.
lynall
22 Apr 2012
Kent
I took apart an eber pump the other day and found a wood screw perfect for removing the gauze filter with no damage.
Lynall
LionsDen
25 Apr 2012
Hertfordshire - London & South Coast
www.bbiuk.com
stuhaynes
25 Dec 2009
Yorkshire
www.best-camping-stoves.com
