geem
I climb in and out of the dinghy using the guardwires every day. The dinghy is hoisted each night and sits against fenders that lean on the guardires. At anchor, the main halyard is tied off to top guardwire. All these things cause movement of the guardwires but in 12 years there is not a single broken strand. If the boat sat there, unused, none of this movement and load would exist. Using the boat everyday creates wear. I don't believe dyneema would suit the way we use the guardwires. It would fluff up rapidly at the stanchion holes. Our mizzen dyneema runners wear where they contact anything, but being 8mm thick, they can take some wear. This size rope wouldn't be possible on the guardwires due to the hole size in the stanchion.Unless your boat is stored in a lightless, vacuum chamber things wear no matter how many miles you travel.
To check this please visit any 'boat graveyard' and see the wear and tare on hulls that have not moved in decades.
Additionally, the props for our guardrail mounted solar, sit on the bottom guardwire. These props are timber. The props get adjusted through the course of the day. There is zero wear on the guardwires. Dyneema would be the wrong choice for us.
Dyneema has its place. All our halyards are dyneema. We have dozens of dyneema soft shackles and our guardwires are lashed with dyneema. I am a big dyneema fan but only where it makes sense
