geem
Not all stachions are inadequately constructed. We have a very heavy aluminium toerail bolted through the deck with M8 bolts every 100mm. The aluminium stanchion bases are bolted through the toerail with 3 bolts and they insert in the toerail such that they lock in place. The stanchions themselves are longer than standard and made of solid aluminium. They are far more robust than you see on a modern production boat. This allows us to put far more load on them with no ill effects.I
I like stainless. It lasts. But there are places for Dyneema.
- We don't hang fenders on lifelines or use them for climbing. That's a good way to get leaks.
- The Dyneema sections are places where lifelines would be useful but were not included by the manufacturer. For example, on my F-24 I added Dyneema guard rails where the outboard tips up and extensions from the pulpit and sternrail (trimarans often don't have guardrails on the amas).
- You can attach Dyneema to stanchions with luggage tags and other tricks that would require welding with stainless lifelines.
- The life expediencies vary with both, but 20 years seems realistic with stainless and 10 years with Dyneema. Stainless corrodes in the sockets and is prone to kinking. Dyneema wears and is affected by UV, but going 1-2 sizes over buys a lot of allowance. We went oversize with Dyneema, because it is more comfortable to handle and still very light. None are less than 6 mm. On both boats, the main sections are stainless.
- Tension. World Sailing gives a figure for tension. More than that only increases the tension during a fall and bends the stanchions inwards. Slack is bad, but overly tight is also poor practice. If a gate reduces tension then the gate is very poorly adjusted; I don't understand the comment.
- Gates vs. no gates. Yes, a gate is a potential failure point. One the other hand, gates can also enhance safety. Recovering an MOBs through a gate is loads easier and there have been many, many nasty falls caused by tripping over a lifeline while boarding. I think the net advantage clearly goes to gates for most cruisers. Racers are free to feel differently. If any of the crew are very short, elderly, or disabled, no gates often mean no safe sailing.
Using 7x19 wire, it is not prone to kinking. Its designed to go around corners.
We chose not to have gates. We much prefer the ultimate strength of continues guardwires. They are our handhold when going forward at sea.
I don't see a good reason for having gates for recovery of a MOB. In 25 years on boat ownership, we have never needed to recover a MOB. There are far more difficult aspects of MOB recovery than worrying about having a gate.
If somebody can't climb over our guardwires then they really shouldn't be on our boat in the first place. It's not intended to be an old folks home
